• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Member
    Accepted Solution
    Varying Height Retaining Wall
    477 Views, 11 Replies
    01-31-2013 03:45 PM
    I am having trouble creating a retaining wall subassembly that is equipped with varying height in order to follow an existing ground surface. I would like to find out how to attatch a point towards the top of the wall to the existing ground surface, so the wall height automatically adjusts to reach the top of the road cut.
    The design is for a basic road along a steep slope. Before proceeding with the left side of the assembly, I wanted to create this varying height retaining wall.
    I have attached an image of the assembly for reference. The ultmite goal would be to have the wall height vary along the corridor to meet the existing ground just below the top of wall.
    Any help would be greatly appreciated. Using Civil 3D 2013
    Cheers
    Please use plain text.
    Valued Mentor
    fcernst
    Re: Varying Height Retaining Wall
    01-31-2013 04:06 PM in reply to: anthonytillemans
    This is what the RetainWallVertical subassembly does.
    Ernst Engineering
    Fred Ernst, PE
    C3D 2013 SP1, C3D 2014
    W7x64; i7 8gb; Radeon HD 5700
    www.ernstengineering.com
    Active Member
    02-05-2013 09:30 AM in reply to: anthonytillemans
    Using the RetainWallVertical, what parameter would be the appropriate one to attach to the surface? I'm assuming it would be the Top Height.
    I'm not sure how to attach parameters to the target surface. I've tried going through the Assembly Properties, under the Construction tab, and using Parameter Reference, but I don't see the correct option available in the "Get Value From" dropdown list.
    Valued Mentor
    Valued Mentor
    sjg
    02-05-2013 10:36 AM in reply to: anthonytillemans
    It will be a target within your corridor, similar to a target for daylighting.
    Steve Goessling
    Land Consultants
    Civil3D 2012 (Service Pack 2.1)
    Windows 7, 64 bit
    Intel i7 2600 @ 3.40Ghz
    16 GB RAM
    Nvidia Quadro 600
    Active Member
    02-05-2013 10:42 AM in reply to: sjg
    Where in the settings do I go to specify the target?
    Valued Mentor
    Valued Mentor
    sjg
    02-05-2013 11:06 AM in reply to: anthonytillemans
    See attached image. Select corridor, right click, select corridor properties, Under the parameter tab, select set all target, you should see RetainWallVeritcal under the surfaces section. set your surface you want the wall to daylight to.
    Steve Goessling
    Land Consultants
    Windows 7, 64 bit
    16 GB RAM
    Nvidia Quadro 600
    Active Member
    02-05-2013 11:14 AM in reply to: sjg
    Thanks heaps
    Valued Mentor
    Valued Mentor
    sjg
    02-05-2013 11:32 AM in reply to: anthonytillemans
    Please pick Accept as Solution, if that answered your question.
    Steve Goessling
    Land Consultants
    Windows 7, 64 bit
    16 GB RAM
    Nvidia Quadro 600
    Active Member
    02-06-2013 11:29 AM in reply to: anthonytillemans
    Thanks again for the previous help. I was able to link the top of the retaining wall to the existing surface, but now I would like to link the wall footing to a certain depth relative to the same existing surface.
    Essentially, I want to maintain a 5' width of horizontal cover between the left edge of the footing and the existing surface. I believe this could be accomplished by somehow creating a variable footing cover height relative to a 5' horizontal distance from the surface in combination with a daylight subassembly.
    The purpose of this 5' horizontal cover is to eliminate the need for a fill slope stemming off the back of the wall. The proposed road location is along a very steep slope where a fill slope is undesirable. With the footing being buried deep enough, no fill slope will be needed.
    I have attached an image of my assembly with some text to detail my idea.
    Any help would be great.
    Thanks in advance
    Valued Mentor
    fcernst
    02-06-2013 12:00 PM in reply to: anthonytillemans
    "The proposed road location is along a very steep slope where a fill slope is undesirable."
    This wall scenario may be a better choice for this stretch of steep slope where you don't have much lateral purchase. Also, your 5' offset scenario doesn't necessaritly ensure a minimum footing depth is always achieved.
    Coordinate with your structural engineer on this.
    Ernst Engineering
    Fred Ernst, PE
