• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    New Member
    chris.pettigrew
    VIEWPORT TYPE
    939 Views, 13 Replies
    04-16-2012 02:35 PM
    Typically when setting up a viewport in paper space I can change the viewport type at the bottom of the properties dialog box. In 2013 the option is available, but it will always snap back to undefined. I'm sure it is a setting somewhere. Any help would be appreciated. Thanks,
    Please use plain text.
    Re: VIEWPORT TYPE
    04-16-2012 07:48 PM in reply to: chris.pettigrew
    Interesting...  I seem to be noticing the same problem.
    Guess I need to explore this and try to figure it out, since I'm supposed to be doing some training later this week in how to create P&P sheets...  I hope nothing is broken in C3D 2013.  (Luckily, I think we'll be using C3D 2012, and not C3D 2013...)
    Sinc
    Re: VIEWPORT TYPE
    04-17-2012 10:38 AM in reply to: Sinc
    I am having the same problem.  No soliution yet.
    Matt Kolberg
    Cansel - Autodesk Division
    http://www.cansel.ca/
    Re: VIEWPORT TYPE
    04-17-2012 03:38 PM in reply to: mathewk
    Kind of a bad problem...
    I wouldn't be in a hurry to jump to C3D 2013 just yet.
    Sinc
    Re: VIEWPORT TYPE
    04-17-2012 03:51 PM in reply to: Sinc
    Interestingly, if you open a 2012 file with that viewport already set, it stays set.  However, you can't change it in 2013.
    Matt Kolberg
    BrianHailey
    Re: VIEWPORT TYPE
    04-17-2012 09:41 PM in reply to: chris.pettigrew
    I've been able to duplicate the issue on my system as well.
    Re: VIEWPORT TYPE
    04-17-2012 10:05 PM in reply to: chris.pettigrew
    I submitted a case to support but I havbe yet to hear back. A fairly serious problem if you're setting up a layout for use with the section and plan production tools.
    Matt Kolberg
    Re: VIEWPORT TYPE
    04-18-2012 08:50 AM in reply to: chris.pettigrew
    I just tried this also and get the same problem.
    I think this has been the worst release since r13.
    Civil 3D 2013 x64
    Civil 3D 2014 x64
    Windows 7 64-bit
    6GB RAM
    Re: VIEWPORT TYPE
    04-19-2012 12:17 AM in reply to: engrtech
    Remember the initial release of 2007...?  :smileywink:
    Sinc
    Re: VIEWPORT TYPE
    04-19-2012 07:27 AM in reply to: chris.pettigrew
    Found a workaround for this. There is a new property preview sysvar PROPERTYPREVIEW. Turn it off.
    Matt Kolberg
