• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    coopdetat
    VIEWCUBE skewed from WCS
    556 Views, 5 Replies
    09-27-2012 08:32 AM
    Hello all,
    I've got a strange problem with my ViewCube.  My screen is showing the world ordinate system as it should in the standard plan view ( X horizontal,Y vertical); however, my ViewCube is skewed to the right about 30° (top view and rotated about 30° right). It is set to orient to the current UCS and the current UCS Is World. If I use the ViewCube to change the setting and orient it as top view orthogonal (north straight up) my view (UCS World) gets twisted left by about (not exactly) 30°.
    Am I missing something or is this abnormal ViewCube behavior?
    I really don't need the ViewCube and usually turn it off but this just bugs me.  Does anyone have any ideas about what's causing this or how to fix it? T
    ---------------------------------------------Signature--------------------------------------------
    Civil Design Professional Since 1983 (Intergraph), AutoCAD since 1989
    It is said that a fool's voice is known by multitude of words... I'm
    just writing this stuff instead of saying it outloud... that's my loophole.
    Windows 7 Professional 64-bit - Service Pack 1
    Intel﴾R﴿ Core﴾TM﴿ i7-3820 CPU 3.60GHz; 16 GB DDR3 Dual Channel RAM
    nVidia Quadro 4000; AutoCAD Civil 3D 2013, sp1
    Please use plain text.
    *Expert Elite*
    Re: VIEWCUBE skewed from WCS
    09-27-2012 08:52 AM in reply to: coopdetat
    Your North direction has been altered in the GEOGRAPHICLOCATION settings. This should be 0.
    Jeff_M, also a frequent Swamper
    coopdetat
    09-27-2012 09:49 AM in reply to: Jeff_M
    Thank you.  Yet another feature that I have no use for so I never learned anything about it.  It seems to me that such features should be off by default rather than on.  GEOMARKERVISIBILITY=0 is a setting I had to add to my Acaddoc.lsp file.  All they do is force those that will not use them to find a way to disable them or turn them off.  Since no one here uses this, how and why it got set to a skewed angle baffles me.  It has nothing to do with reality for the site.
    *Expert Elite*
    09-27-2012 10:10 AM in reply to: coopdetat
    Your signature line is cut off so I don't know if it shows which version of C3D you are using. I know that if I open a drawing in C3D2013 in which I've set a coordinate system in C3D2012, the North direction, and sometimes the UP direction, get randomly changed. I must go in and change them back to 0 & Z+ every time. One reason I'm still using 2012.
    If you find a response which answers your question, please be sure to accept the actual post which helped you as the solution. This will help future searchers quickly find answers to their own questions. Thanks!
    *Expert Elite*
    neilyj
    09-27-2012 12:15 PM in reply to: coopdetat
    Is there a command line equivalent so that this can be incorporated into acaddoc.lsp??
    I think it may have arisen for me by migrating my template from 2012 i.e open up my dwt and save as 2013 version..!!!
    Does this setting actually affect anything coordinate wise etc?
    neilyj
    (No connection with Autodesk other than using the products in the real world)
    IDSP Premium 2014 (mainly Civil 3D 2014 but also 3ds Max Design)
    Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
    16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
    NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
    *Expert Elite*
    09-27-2012 01:19 PM in reply to: neilyj
    There might be something that can be done via lisp, will have to look into that. I don't think it affects C3D at all, but I could be wrong.
