AutoCAD Civil 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Update date stamp with fields
- Highlight
- Email to a Friend
- Report Inappropriate Content
Settings on the User Preferences Tab (Options Dialog Box) control whether fields are updated automatically or on demand (FIELDEVAL system variable). The Date field cannot be updated automatically regardless of the setting of FIELDEVAL.
Not happy. This should update everytime I save.
Re: Update date stamp with fields
- Highlight
- Email to a Friend
I think I got it to work better with a diesil string. Try doing a search on that.
Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
__________________________________________________________
Credit where credit is due! Give kudos or accept as solution whenever you can.
- Highlight
- Email to a Friend
Elaine, try using Savedate instead of Date when you pick the field name.
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
- Highlight
- Email to a Friend
I use a custom date stamp that is based on Fields. I usually don't see it updated on the screen but do see the updated information on the plot. When you plot is the date stamp updated?
Allen
- Highlight
- Email to a Friend
My date stamp is also based on fields. My field eval is set to 31 which should update my file path/date string whether I plot, save, etc. I researched all of this on Friday and found a post to use the "All" in Fields, then "Date", then select the format. Everything was working fine and then I come to work today and the date string is no longer updating. Hence I went back on line and then happened to find the information concerning the updating, using fields, in text strings that I posted to this forum. Now this just shouldn't be rocket science here.We are trying to be productive. The automatic plot stamp is crap for use because depending on the size sheet, the printer, the scale you have to reorient and adjust which takes time and if you forget then you have to replot because you got in a hurry and didnt preview and if the drawing has a lot of images then the preview gets stuck and yes I am running 64 bit. kick **** computer.Breathe I just want accurate File path -date stamp. Any ideas??. I think I have an old Rtext but if I remmeber right they don't update except on insertion.
- Highlight
- Email to a Friend
That would be a big NO. Does not show updated on plots
- Highlight
- Email to a Friend
Tim the Savedate was what I was using that wasn't working.
- Highlight
- Email to a Friend
Attached is what I use. Since I want the Plot Date, that's what I'm using in the field. So when I plot it updates.
Allen
- Highlight
- Email to a Friend
We were using RTEXT here. Works fine, updates on every regen, on file open etc. The only reason we left it was because it can only be left justified. MTEXT with fields or diesel expressions can be right or centre justified.
- Highlight
- Email to a Friend
Exactly. Used Rtext, switched to fields using diesel expressions "$(edtime, 0, MON DD"," YYYY - H:MMam/pm)". Works like a charm. Kudos.
Senior Civil Engineer
