• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    *Expert Elite*
    neilyj
    Accepted Solution
    Update Field isn't updating as expected
    176 Views, 12 Replies
    01-07-2013 12:58 AM
    I have a field in a block and all the FIELDEVAL variables are set as shown in the screenshot but the field doesn't update on REGEN - I have to issue the UPDATEFIELD command to update the field.
    There was a previous thread started in March 2011 with the same problem - is this another unresolved bug??
    neilyj
    (No connection with Autodesk other than using the products in the real world)
    IDSP Premium 2014, Civil 3D 2013 (UKIE) Hotfix 3; Win 7 Pro x64
    256Gb SSD, 300Gb 15,000 rpm HDD
    16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
    NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
    Please use plain text.
    *Expert Elite*
    Re: Update Field isn't updating as expected
    01-07-2013 01:08 AM in reply to: neilyj
    What field-type is it? If it's a save-date/time or plot-date/time then it would/should not update with a _REGEN.
    - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
    *Expert Elite*
    neilyj
    01-07-2013 01:15 AM in reply to: neilyj
    That was my initial thought but It's just a simple DATE field
    neilyj
    *Expert Elite*
    01-07-2013 01:23 AM in reply to: neilyj
    and how did you get it now to "2013"? Have you defined it new or saved or what happend? In the last screenshot it was 2012.
    If you have the old drawing, can you delete all but this block and upload it so we can play with trying to update it (I can test it with Civil3D, Map3D, AutoCAD all 2013 if necessary).
    - alfred -
    Alfred NESWADBA
    *Expert Elite*
    neilyj
    01-07-2013 01:25 AM in reply to: neilyj
    I issued the UPDATEFIELD command and selected the block
    neilyj
    *Expert Elite*
    01-07-2013 01:38 AM in reply to: neilyj
    OK, I tried it in a new drawing and ... yes, same issue, a _REGEN does not update that "DATE" field (not with Civil3D 2013 SP1, not with AutoCAD 2013 SP1.1).
    That brings me to the question: what does the field "DATE" represent, if it's not a save-time and not a plot-time ==> whatfor is it needed or whatfor is it designed?In the help I have not found it.
    For me: now I know why I have not had that problem yet: because I never used it; I used SAVEDATE or PLOTDATE and they work without any issues (yet).
    But sorry to have no solution for you, - alfred -
    Alfred NESWADBA
    *Expert Elite*
    neilyj
    01-07-2013 01:48 AM in reply to: neilyj
    Indeed - as it doesn't seem to update on open or save either - only manually after UPDATEFIELD.
    I have raised a support case and will post the response when (if) I get one
    neilyj
    01-07-2013 07:57 AM in reply to: neilyj
    I'm guessing this is functioning as intended? As opposed to editing the date, issuing updatefield populates it with the current date.
    Eric Collins, P.Tech.(Eng.)
    Win XP Pro SP3 32 bit
    Xeon E5520 @ 2.27 GHz
    4 GB RAM
    Civil 3D 2012
    *Expert Elite*
    neilyj
    01-07-2013 08:05 AM in reply to: ericcollins6932
    It seems that this behaviour is indeed as intended - from Help
    "...The Date field is updated by UPDATEFIELD, but it is not updated automatically based on the setting of the FIELDEVAL system variable..."
    I only need to bother with this field update every January but another example of inconsistency in the workings of Civil 3D...??
    neilyj
    01-07-2013 08:49 AM in reply to: neilyj
    Ever use a diesel expression for date? See forum posting attached. It might be a serviceable workaround.
    http://forums.autodesk.com/t5/AutoCAD-LT/Inster-a-field-to-show-the-current-date/td-p/3356011/page/2
    4 GB RAM
    Civil 3D 2012
