• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Valued Contributor
    Accepted Solution
    Unwanted zoom
    127 Views, 5 Replies
    11-27-2012 09:19 AM
    Upon selecting an object while in HATCH command, the display zooms to extents before finishing the command. Thus, if I want to hatch multiple selections at one time, this makes it extremely time consuming to have to zoom back into my objects each time. Obviously very frustrating given I'm working on a drawing with very large extents (an entire city, actually!) What variable am I missing?
    Thanks for any assistance.
    Please use plain text.
    *Expert Elite*
    Re: Unwanted zoom
    11-27-2012 09:50 AM in reply to: jlawrence
    I can't reproduce your issue, but...
    What are you using for your boundary set? If it's set to Current Viewport, try setting it to a selection set of objects. Does that help? Shot in the dark, but it's something to try...
    Tim Corey, Owner
    Delta Engineering Systems
    Redding, CA
    Autodesk Authorized Value-Added Reseller
    Valued Contributor
    Re: Unwanted zoom
    11-27-2012 11:16 AM in reply to: tcorey
    Thanks, but I've tried that with no success. The zoom issue also happens when I click to the MODEL tab no matter what view I had left it in. There must be a simple setting somewhere that I'm just forgetting...
    *Expert Elite*
    Re: Unwanted zoom
    11-27-2012 11:40 AM in reply to: jlawrence
    UCSFOLLOW
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
    Valued Contributor
    Re: Unwanted zoom
    11-27-2012 11:44 AM in reply to: troma
    That's the one! I knew it was something easy that was escaping my little brain-thanks!! :smileyhappy:
    *Expert Elite*
    Re: Unwanted zoom
    11-27-2012 11:58 AM in reply to: jlawrence
    No prob.  I didn't know it messed with the HATCH command, but when you mentioned zooming when switching into Modelspace I figured it was worth a check.
