• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Undo has been disabled...
    1021 Views, 5 Replies
    05-09-2012 01:07 PM
    Undo has been disabled in order to prevent undo file overflow...
    Is there anyway to increase the Undo capabilities.
    Please use plain text.
    Re: Undo has been disabled...
    05-09-2012 05:17 PM in reply to: bcales
    I've never seen this. How about saving and closing the drawing and reopening it?
    Matt Kolberg
    Cansel - Autodesk Division
    http://www.cansel.ca/
    sboon
    05-09-2012 06:53 PM in reply to: mathewk
    I've seen it fairly often, especially while doing a lot of corridor section edits.  I think that there's a way to turn off the undo function and then turn it back on again.  When you do that the program apparently starts a new file.
    05-09-2012 08:42 PM in reply to: sboon
    SBoon wrote:
    ... I think that there's a way to turn off the undo function and then turn it back on again. ...
    Undo, Control, None or One
    Undo, Control, All
    oceanside
    01-09-2013 01:17 PM in reply to: bcales
    I have done this so many.....times today.  It doesn't work.  Software is Civil 3D 2013.  A couple of computers have the message "Warning! Undo has been disabled in order to prevent undo file overflow.  You may re-enable it via the undo command.  The undo file length was 1768915703 bytes".  I've been using the UNDO command since Release '08 & I've never seen this problem.  I have search & search & nothing seems to work....how do you control the length of the UNDO command.  I don't understand how UNDOCTL works cause it's read only.  Does anyone have a solution?
    the best is at the beach!
    sboon
    01-09-2013 01:19 PM in reply to: oceanside
    Save - Shutdown - Restart the program.
