• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Member
    Undefined Alias Referenced
    215 Views, 8 Replies
    12-19-2012 12:19 PM
    Hello
    I've been getting this Undefined Alias Referenced error showing up everytime I open one specific drawing.
    Anyone know how to resolve this message?
    Also, I'm not sure if this is related to the first part. In the same drawing I have several png files that I can't get rid of.
    Please use plain text.
    *Expert Elite*
    rkmcswain
    Re: Undefined Alias Referenced
    12-19-2012 12:37 PM in reply to: jasonbolan4741
    Member
    12-19-2012 12:55 PM in reply to: jasonbolan4741
    Thanks! That worked.
    I still have those pgn files in my xref manager.  All of the files are unreferenced but i cannot detach them
    Valued Mentor
    LisaPohlmeyer
    12-19-2012 01:23 PM in reply to: jasonbolan4741
    If you use the tree view in the reference manager, are they nested in another file?  If not, can you map them to a png file that you can see and then remove them that way?
    Lisa Pohlmeyer
    Williamson Co. Dept. of Infrastructure
    Intel i7 3.33Ghz, 16Gb RAM
    Nvidia Quadro 2000D
    C3D 2012 SP3, C3D 2014
    Win 7-64
    Please mark this as the solution if it resolves your issue.
    Member
    12-20-2012 05:38 AM in reply to: LisaPohlmeyer
    There are two reference files in this drawing. Neither of the two references have the png files in them.
    The saved path the png files are trying to follow does not exist on my computer.
    c:\docume~1\ke229\locals~1\temp........etc
    I don't believe we ever had these files therefore I cannot map them back. So is there another way of removing them from the drawing outside of the xref manager?
    *Expert Elite*
    12-20-2012 11:36 AM in reply to: jasonbolan4741
    You don't have to map back to the 'right' file.  You can map the reference to any file at all.  (Possibly any .png, rather than any file.)
    I don't know if that will help you to remove them, but there you go.
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
    Valued Mentor
    LisaPohlmeyer
    12-20-2012 11:40 AM in reply to: jasonbolan4741
    that's exactly what I was trying to say.  This happens to me all the time when someone references a Google Earth image and they save that image on their C: drive.  Then when I open it, I don't have the image.  I map it to another image on my computer, then I can see it and remove it.
    Lisa Pohlmeyer
    Nvidia Quadro 2000D
    Win 7-64
    Valued Contributor
    C3D_TomR
    12-20-2012 03:15 PM in reply to: LisaPohlmeyer
    Purg any unused blocks in the drawing then try to detach the image. If that doesn't work you can then use the filter command to select all images in the drawing to erase (delete). You should then receive a message about detaching the image(s).
    Valued Mentor
    LisaPohlmeyer
    01-15-2013 06:07 PM in reply to: jasonbolan4741
    Expand the details section at the bottom. You can map the saved path to a different png that you can select and remove.
    Lisa Pohlmeyer
    Nvidia Quadro 2000D
    Win 7-64
