• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Unable to assign coordinate system when importing LAS files.
    341 Views, 5 Replies
    08-08-2012 02:41 AM
    I have been trying to import LAS files via Civil 3D 2011.
    To do this I first turn the workspace to ''Tool based geospatial''. Then i assign a global coordinate system which is the same one as the LAS file i am importing. The in the task pane window (comand: mapwspace) under display manager tab i rightclick on map base --> data --> add point cloud data --> create new index and then choose the file I want to import. Here i have some trouble; in the create new index window i am unable to assign a coordinate system, i can find the one i need but i cant select it (or any other), it presists on staying unselected. I am able to create an index without a coordinate system but I need it with the right coordinates.
    Have you had this problem?
    Thank you
    Please use plain text.
    TRogers
    Re: Unable to assign coordinate system when importing LAS files.
    08-08-2012 05:15 AM in reply to: Breshaki
    Create the Point Cloud from your Prospector in Civil 3D (right-click on Point Cloud and Create), not doing the map functions.  This may work better for you.  In the wizard you will have the option to set the coordinate system.
    If the issue was resolved by this method, please click on "Accept As Solution"
    *Civil 3DJ*
    Todd Rogers
    Visit my blog here.
    08-08-2012 06:45 AM in reply to: TRogers
    Thanks for the reply.
    I followed your instrctions but i get an error box (see the attachment) right at the end of the creation process. Nontheless the isd file is created and i can import it and create a surface BUT the original LAS is not in the coordinate system I want and I am unable to convert it to the right coordinate sys. Do you have any advice?
    I have tried to simply change the global coordinate system after i have created the point cloud (thinking since its original coordinates have been set it should know how to convert properly) but it just dosent work.
    TRogers
    08-08-2012 06:48 AM in reply to: Breshaki
    This usually occurs when using the wrong format.  Is the LAS file small enough to attach here?  If not, can you send it to me some other way?  My email address is trogers@tcadsys.com.
    *Civil 3DJ*
    Todd Rogers
    Visit my blog here.
    Valued Mentor
    LeafRiders
    08-08-2012 02:58 PM in reply to: Breshaki
    Is the goal to import your survey points in one coordinate system in order to translate it into another? If so, there is some information here. See reference as it should help you explore an alternate method to the "point cloud" method mentioned above. http://civil3dplus.wordpress.com/tag/coordinates/
    08-08-2012 11:08 PM in reply to: TRogers
    I couldnt attach it here, i'll send you a file to your email.
