• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Valued Mentor
    fcernst
    Unable to Import STM file into Civil 3D
    136 Views, 6 Replies
    11-30-2012 02:09 PM
    I executed Edit in Storm Sewers to work on the Pipe Network in Civil 3D. I made some changes in Storm Sewers, now I want to Import back to Civil 3D.
    Nothing is happening in Civil 3D when I try to Import with either of the choices, picking Overwrite or to Create a new pipe network. I am not sure what I am doing wrong.
    I have attached the drawing file and the STM file.
    Ernst Engineering
    Fred Ernst, PE
    C3D 2013 SP1, C3D 2014
    W7x64; i7 8gb; Radeon HD 5700
    www.ernstengineering.com
    Please use plain text.
    *Expert Elite*
    Re: Unable to Import STM file into Civil 3D
    11-30-2012 02:22 PM in reply to: fcernst
    Fred, I don't know what's wrong with that drawing file, but I can create a new drawing and import your STM just fine. I cannot import into the drawing you attached.
    Tim Corey, Owner
    Delta Engineering Systems
    Redding, CA
    Autodesk Authorized Value-Added Reseller
    Valued Mentor
    fcernst
    11-30-2012 02:28 PM in reply to: fcernst
    Thank you Tim.
    You said new file...So with 2013 SP1, in your other drawings, can you send out a network to Storm Sewers, make changes, and bring it back into Civil 3D to update the network in the existing drawing just fine?
    Ernst Engineering
    Fred Ernst, PE
    *Expert Elite*
    11-30-2012 02:58 PM in reply to: fcernst
    Hi Fred,
    Using other drawings, I can export to STM, modify in Storm Sewers, save STM, import STM back into the same c3d drawing, modifying the existing network.
    Using the drawing you attached with the STM you attached, I could not insert into the dwg, but I could insert your STM into a new dwg.
    Tim
    Tim Corey, Owner
    Redding, CA
    Valued Mentor
    fcernst
    11-30-2012 03:02 PM in reply to: tcorey
    Thanks, and that's 2013 SP1?
    I could import that file into a new drawing as you mention, just can't get it back into the original drawing as you mention.
    Ernst Engineering
    Fred Ernst, PE
    *Expert Elite*
    11-30-2012 03:16 PM in reply to: fcernst
    Yes, 2013 with SP1.
    Tim Corey, Owner
    Redding, CA
    jim
    New Member
    jim
    12-03-2012 07:12 AM in reply to: fcernst
    We are having the same problem trying to re-import an STM file back into our original drawing to overwrite the pipe network.  It doesn't work.  Did anyone ever come up with a fix or work-around for this?  We are on C3D 2013 with all SP's updated.
    Meredith Hammill
    Latham-Walters Engineering
    C3D SP1
    Windows 7 SP1
    Dell Intel Xeon CPU E31225 @ 3.10 GHz
    64-bit 16G Ram
