• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Civil 3D
    New Member
    UCS ICON
    166 Views, 2 Replies
    01-15-2013 06:43 AM
    I am currently working on a culvert drawing, using two view ports for my plan and profile sheet. As you can see below in my attachment, the UCS icon in the upper viewport is distorted, I do not how this occured nor do I know how to correct it. Would appreciate some input. Thanks
    Please use plain text.
    AllenJessup
    Re: UCS ICON
    01-15-2013 06:50 AM in reply to: ENGTECH15
    With no information other than the screen shot. I would guess that your Viewtwist is not 0°. Type VIEWTWIST to check. Use the DView command to reset.
    It isn't a bad thing if it's not 0°. Mine often isn't. That's how I make a road that isn't east to west be parallel to the boarder.
    Re: UCS ICON
    01-15-2013 07:22 AM in reply to: ENGTECH15
    UCS with the View option will rotate the UCS to your viewport.
    Matt Kolberg
    Cansel - Autodesk Division
    http://www.cansel.ca/
