Trying to Match Perspective to ViewPort
Message 1 of 9
I am having a really hard time trying to get this to work. If you see the image below. I am trying to make the viewport match the oblique / birds eye view in paperspace. Anybody have an idea how to do this? I do have everything set in real life (1:1) paper and model. The Model space has a 2D Line drawing; while the paper space has a transparent (60%) birds eye view image.
Thanks!
Replies (8)
Message 2 of 9
tcorey
Are you saying you have an image that is a photo taken from a birdseye view and that you want the linework to look like it matches up with that?
Use Saveas to save the drawing to a different file if you don't want to overright your existing drawing.
Move the image to modelspace.
U ADERSHEET command to rubbersheet the linework to the image.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 3 of 9
You are correct. could you possible show me an example? I am having trouble getting the image to overlay ontop of the line work. I hope that makes some sense.
Message 4 of 9
tcorey
Use eTransmit to make a package of your drawing and image, post here, and I'll take a look...
Tim
Tim Corey
Redding, CA
Message 5 of 9
Message 6 of 9
One thing to try...
You can apply the image as a "background" to a saved view in paperspace, then 3D orbit the drawing until the linework matches up with the image in the background. See the "View" command and" background override" options in the view dialog for setting the image as a background. You shouldn't need to set up a camera or anything like that. The only thing I'm not sure of is the transparency. I don't think you can set a transparency to an image applied as a background for a view. But you can edit the image in paint or something and lighten in up a little to give it a faded back appearance if need be. Hope this helps.
Message 7 of 9
tcorey
Open your drawing.
Bind the Xref as an Insert and Explode it.
Run ADERSHEET command.
Pick as many Base Points and Reference Points as you design. More points = higher accuracy. Pick a base point on your linework and then pick the reference point on the image in the location that linework base point should be after rubbersheeting.
After picking as many base and ref points as you design, press enter. Use the Select option and then select all the linework, but not the image. Hit Enter. If you get  a Map Error dialog, hit close.
Best regards,
Tim
Tim Corey
Redding, CA
Message 8 of 9
Thank you so much for the explaination. It did work! I do have one more question; is there a way you can rotate / match the view of the birds eye / oblique photo? So when I go to the top view, it looks like a plan view?
Message 9 of 9
tcorey
Without knowing the height of the camera and its angle towards the subject of the photo, I don't know how you would do that mathematically.
If you want to trial and error it, you could use the Viewcube to spin the view until it looks good, or use the Vpoint command to place the viewpoint where you estimate it should be.
If my previous post solved your initial question, please mark it accept as solution so others that might have the same question will be able to quickly find their answer without reading the entire thread. Thanks.
Best regards,
Tim
Tim Corey
Redding, CA
