AutoCAD Civil 3D
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Re: Troublesho oting slowness
Options
- Highlight
- Email to a Friend
02-24-2012 07:50 AM in reply to:
rdlongbow
You might benefit from working locally by using Vault to check out your projects locally and store them back on the server when you are done. Invalid links, shortcuts, broken mapped drives, offline printers, digital signatures, and overall WAN latency can contribute to your slowness problem.
Travis Nave
My Expert Contributions to the Discussion Groups:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
My Expert Contributions to the Discussion Groups: FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!Re: Troublesho oting slowness
Options
- Highlight
- Email to a Friend
02-24-2012 09:31 AM in reply to:
TravisNave
We are not setup for Vault. Just getting on a new server should do the trick, though.
As an example, when I tested a project with a pipe network on both the 2003 and 2008 servers, the results were pretty dramatic. Listing the pipes (31) in Toolspace on the 2003 server took 1 min. 45 sec. Sometimes it took much longer. On the 2008 server, it took 2 secs.
