AutoCAD Civil 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Trouble using Civil 3D commands
- Highlight
- Email to a Friend
This is true in all the 3D commnads
Re: Trouble using Civil 3D commands
- Highlight
- Email to a Friend
problem lately due to starting "AutoCAD Civil 3D 2009 as AutoCAD" which
means this is not Civil 3D.
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<abcd1827565> wrote in messageI
href="news:6129474@discussion.autodesk.com">news:6129474@discussion.autodesk.com...
try to make a simple surface in 3D, this is what appears on the command line
"Unknown command "AECCCREATESURFACE". Press F1 for help." This is true in all
the 3D commnads
- Highlight
- Email to a Friend
Loading AEC Base...
Loading AEC Base Extended...
Loading AEC Base UI...
Loading AEC Project Base...
Loading AEC Base GUI...
Loading AEC Schedule Data...
Loading AEC Schedule...
Loading AEC Object Explode...
Loading AEC Layer Manager...
Loading AEC Architectural Base...
Loading AEC Project UI...
Loading AEC Utilities...
Customization file loaded successfully. Customization Group: CIVIL
Customization file loaded successfully. Customization Group: MAP3DGEOSPATIAL
Customization file loaded successfully. Customization Group: MAPCLASSIC
Customization file loaded successfully. Customization Group: ACAD
Customization file loaded successfully. Customization Group: CONTENTSEARCH
Regenerating model.
Initializing........
C:\Program Files\AutoCAD Civil 3D 2009\AcMapWorkspace.arx cannot find a dll or
other file that it needs.
C:\Program Files\AutoCAD Civil 3D 2009\AcMapDwfApi.arx cannot find a dll or
Failed.
AcMapWorkspace.arx Load Failed
AcMapDwfApi.arx Load Failed
C:\Program Files\AutoCAD Civil 3D 2009\AcMapDwfUI.arx cannot find a dll or
C:\Program Files\AutoCAD Civil 3D 2009\Civil\AeccUiModel.arx cannot find a dll
or other file that it needs.
AutoCAD Express Tools Copyright © 2002-2004 Autodesk, Inc.
AutoCAD menu utilities loaded.
All ACAD commands work, but none of the Civil 3D commands work, even though the Civil 3D menus and their commands are showing. Every Civil 3D command results in an error such as this:
Command: Unknown command "AECCCREATEPOINTS". Press F1 for help.
Civil 3D worked fine after installation. Then while attempting to switch between workspaces it crashed and then the Civil 3D commands didn't work any more.
Help!
- Highlight
- Email to a Friend
Allen
- Highlight
- Email to a Friend
-V
- Highlight
- Email to a Friend
This link doesn't work anymore. I'm having the same problem with Civil 3D commands not working and I'm positive I'm opening and using AutoCAD Civil 3D. Please help!
- Highlight
- Email to a Friend
I can't find it on the Autodesk site. They may have pulled it down. What version are you working in?
Allen
- Highlight
- Email to a Friend
AutoCAD Civil 3D 2010. Thanks for the prompt reply!
- Highlight
- Email to a Friend
Nothing occurs to me at the moment. I'll poke around and post if I come up with anything. Have you tried the standard - Restart the program and\or reboot?
I'm about to leave. Post what you find and I'll take a look 2morrow.
Allen
- Highlight
- Email to a Friend
Oops, i'm so conditioned to seeing messag boxes come up for missing shape files or xrefs that I failed to read the following one carefully: "This drawing was created with a newer version of Civil 3D. All entities created by Civil 3D within the drawing are in a proxy state. Additionally, all commands, settings, and displays of Civil 3D are disabled for this drawing."
I read that this can be caused by orphaned files so I removed the AECC points in the drawing, recovered, audited; all without resolving the issue. It seems to be simply that I need to contact the drawing owner and ask them to save it as version 2010 from a newer version.
Thanks again for the help.
