• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    *Expert Elite*
    Re: Trimble Feature Codes -> Desckeys
    12-29-2011 12:05 PM in reply to: derek.gray
    Got them, thanks! Now I'll see what I can come up with over the weekend.
    Please use plain text.
    *Expert Elite*
    01-01-2012 03:48 PM in reply to: Jeff_M
    Well, this is what I've come up with.....
    It shows all of the Layers, Blocks, and PointStyles defined in the Trimble FXL. You can add a prefixe to any of these, as shown. Selecting OK the creates a new DescriptionKeySet using the name provided in this form.
    This is the result:
    The Scale settings do not get imported, as I couldn't determine what they were supposed to be doing, so I just assigned all of the PointStyles to "Use drawing scale".
    I you are interested in obtaining this, please shoot me a PM.
    *Expert Elite*
    Neilw
    01-01-2012 06:16 PM in reply to: Jeff_M
    I don't have TGO in front of me so I can't run any tests but you can import a CSV into ACCESS. Is there some reason why you can't make that  work?
    Neil Wilson (a.k.a. neilw)
    Infrastructure Suite/C3D 2013, LDT 2004, Power Civil v8i SS1
    WIN 7 64 PRO
    HP Pavillion h8xt, i7 2600, 12 GB
    RADEON 6450, 1 GB
    http://www.sec-landmgt.com
    *Expert Elite*
    01-01-2012 07:02 PM in reply to: Neilw
    Based on the first post, he can't save to Access97. Based on the CSV file he posted, it doesn't output the required information.
    Member
    12-10-2012 09:30 AM in reply to: Jeff_M
    This would be benifical to us the use of the Trimble feature codes import, would you be able to explain how i can achiecve this?
    Member
    12-10-2012 09:31 AM in reply to: Jeff_M
    Jeff,
    are you able to explain ho wyou got that pop-up window to appear? we have recently invested in Civil CAD 3d and this would be helpful.
    Regards
    Andrew
    *Expert Elite*
    12-10-2012 09:59 AM in reply to: adobrucki
    Yes, this is something I programmed to do using C#. It is currnetly one of the many commands available in the SincpacC3D.
    Member
    12-11-2012 01:15 AM in reply to: Jeff_M
    Jeff_M, so its a add-on not something that can be easily doen wiothout purchasing the software Sincpac?
    *Expert Elite*
    12-11-2012 10:02 AM in reply to: adobrucki
    That's correct. It took me about 5 days to program. It will try to create all symbols and styles to match what is specified in the fxl file. You are more than welcome to test it out, as there is a 28 day free trial availble which includes full functionality of all commands.
    Valued Contributor
    12-11-2012 11:33 AM in reply to: Jeff_M
    Jeff, thanks for tackling my problem. I have downloaded it to play with...
