• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Contributor
    Accepted Solution
    Traverse Adjustment won't
    394 Views, 13 Replies
    12-20-2012 05:30 PM
    I've got a closed traverse that has all the elements, but when I try and analyze it, I get the dreaded error: Insufficient angles, distances or points to calculate this loop. I've attached a screen capture of the traverse - can anyone tell me what it lacks? I've worked through Jason Hickey's process as laid out in Being Civil: Creating a Traverse for Adjustment: http://beingcivil.typepad.com/my_weblog/2009/03/creating-a-traverse-for-adjustment.html and my screen capture looks very similar to his, but I'm not getting any results. Thanks, Randy
    Please use plain text.
    Active Contributor
    Re: Traverse Adjustment won't
    12-20-2012 10:26 PM in reply to: RandyBenson
    i thought I'd add an uncropped view of the traverse editor showing the coordinate columns.The initial backsight point (#38) is a control point that is identical to station 102, except that it is an initial control point. When I try to use point #102 for an initial backsight point, the traverse analysis throws an error saying that it can't determine the initial azimuth (because 102 is a variable traverse point, not a control point). I'm stuck. Everything looks o.k. - it's a closed traverse and it actually comes very close to closing with no adjustments. But the traverse analysis totally
    Valued Mentor
    12-21-2012 02:37 AM in reply to: RandyBenson
    You need a set-up from 101 Backsighting 102 Turing to 38, then you should be able to close it.
    Valued Contributor
    12-21-2012 02:36 PM in reply to: RandyBenson
    YOu can enter the az if it's known and yes , you should be settting on 38 and turning back to 102 .
    you need the angle and distance to close the traverse.
    Send me the FBK file and I will try to work with it for you.
    Surveyor Lee
    Active Contributor
    12-21-2012 04:34 PM in reply to: SurveyorLee
    <settting on 38 and turning back to 102 >
    38 _is_ 102. They're at the same coordinate, it's just that 38 is a control point (won't get adjusted) like 101.
    the [cropped] FBK file isn't very long:
    JOB 1036 MON ! DT12-19-2012 TM06:03:11
    UNIT USFOOT DMS
    EDM OFFSET 0.0000
    SCALE FACTOR 1.0000000
    HORIZ ANGLE RIGHT
    VERT ANGLE ZENITH
    NEZ  101 5000.0000 5000.0000 100.0000 "SET X CP"
    NEZ  2 4938.9680 4683.7770 104.6000 "MAGNL CP"
    NEZ  38 4277.4110 4791.1040 90.6600 "LNT PROD CP"
    ! OPENED BY VERSION 5.2.0, RANGER3 (RS0EC07210).
    ! DATE: 12/17/12, TIME: 08:40:50.000
    ! ACTIVATING TOTAL STATION: TOPCON GPT SERIES MECHANICAL, COM1,1200,EVEN
    ! TARGET PRISM,     HR:1.541 (1.541 + 0.000 OFFSET), PRISM CONST.:0.000MM
    STN  101 5.632 "SET X CP"
    AZ  101 38 259.04510
    BS  38 0.00000
    PRISM  5.055
    ! BS CHECK 101 - 2:ZE91.1922,SD428.72,HD ERR= 106.615751, VD ERR= 90.680095
    ! BS CIRCLE CHECK : ANGULAR ERR= 0.0001
    F1 VA 1002 0.00000 428.720 91.19225 "FD LNT PROD CP"
    ! DATE: 12/17/12, TIME: 09:00:50.000
    ! TARGET PRISM,     HR:1.495 (1.495 + 0.000 OFFSET), PRISM CONST.:0.000MM
    BS  38 0.00000
    PRISM  4.905
    ! BS CHECK 101 - 102:ZE91.1931,SD428.72,HD ERR= -0.000408, VD ERR= -0.017662
    ! BS CIRCLE CHECK : ANGULAR ERR= 0.0000
    PRISM  5.055
    PRISM  4.905
    PRISM  5.055
    PRISM  4.905
    F1 VA 103 271.37565 164.387 85.00455 "SET 60D CP"
    ! DATE: 12/17/12, TIME: 09:40:50.000
    PRISM  5.055
    PRISM  4.905
    PRISM  5.055
    PRISM  4.905
    F1 VA 106 187.26345 242.955 89.05065 "FD MAGNL CP"
    STN  106 5.580 "FD MAGNL CP"
    BS  101 0.00000
    PRISM  5.250
    ! BS CHECK 106 - 101:ZE91.1019,SD242.96,HD ERR= -0.014843, VD ERR= -0.032228
    F1 VA 366 0.00000 242.960 91.10125 "BSCK A106"
    ! DATE: 12/19/12, TIME: 13:33:24.000
    PRISM  4.905
    ! TARGET PRISM,     HR:1.600 (1.600 + 0.000 OFFSET), PRISM CONST.:0.000MM
    PRISM  5.250
    PRISM  4.905
    PRISM  5.250
    PRISM  4.905
    F1 VA 113 263.31585 322.315 87.27320 "FD 4PMMH CP"
    STN  113 5.560 "FD 4PMMH CP"
    BS  106 0.00000
    PRISM  5.160
    ! BS CHECK 113 - 106:ZE92.4405,SD322.36,HD ERR= -0.005178, VD ERR= -0.015144
    ! BS CHECK 113 - 106:ZE92.4404,SD322.365,HD ERR= -0.00011, VD ERR= -0.013821
    F1 VA 367 0.00005 322.365 92.43575 "BSCK A113"
    PRISM  4.905
    F1 VA 116 72.23330 40.355 90.51430 "FD PSPKTC"
    F1 VA 117 153.18580 36.180 89.04070 "FD LNTTC"
    ! DATE: 12/19/12, TIME: 14:03:27.000
    F1 VA 118 252.24340 40.720 89.49200 "FD LNTTC"
    F1 VA 119 333.19190 36.480 92.56290 "FD LNTTC"
    ! TARGET PRISM,     HR:1.573 (1.573 + 0.000 OFFSET), PRISM CONST.:0.000MM
    PRISM  5.160
    PRISM  4.905
    PRISM  5.160
    PRISM  4.905
    F1 VA 120 269.59270 286.777 89.56535 "FD PKNL CP"
    ! DATE: 12/19/12, TIME: 14:30:50.000
    ! TARGET PRISM,     HR:1.576 (1.576 + 0.000 OFFSET), PRISM CONST.:0.000MM
    STN  120 5.567 "FD PKNL CP"
    BS  113 0.00000
    PRISM  5.170
    ! BS CHECK 120 - 113:ZE90.1551,SD286.775,HD ERR= -0.005431, VD ERR= -0.010896
    F1 VA 368 0.00000 286.770 90.15435 "BSCK A120"
    PRISM  4.905
    PRISM  5.170
    PRISM  4.905
    PRISM  5.170
    PRISM  4.905
    F1 VA 121 179.59575 383.587 92.44030 "FD 4PMMH CP2"
    ! TARGET PRISM,     HR:1.524 (1.524 + 0.000 OFFSET), PRISM CONST.:0.000MM
    STN  121 5.532 "FD 4PMMH CP2"
    BS  120 0.00000
    PRISM  5.000
    ! BS CHECK 121 - 120:ZE87.2643,SD383.54,HD ERR= 0.007975, VD ERR= -0.008194
    F1 VA 122 0.00000 383.535 87.26405 "BSCK A121"
    ! DATE: 12/19/12, TIME: 14:58:19.000
    PRISM  4.905
    PRISM  5.000
    PRISM  4.905
    PRISM  5.000
    PRISM  4.905
    F1 VA 102 270.00195 342.358 92.08555 "FD LNTTC PROD CP"
    STN  102 5.490 "FD LNT PROD CP"
    BS  121 0.00000
    PRISM  4.870
    ! BS CHECK 102 - 101:ZE88.5005,SD428.715,HD ERR= 0.020611, VD ERR= 0.012632
    ! TARGET PRISM,     HR:1.486 (1.486 + 0.000 OFFSET), PRISM CONST.:0.000MM
    PRISM  4.875
    ! TARGET PRISM,     HR:1.484 (1.484 + 0.000 OFFSET), PRISM CONST.:0.000MM
    PRISM  4.870
    PRISM  4.875
    PRISM  4.870
    F1 VA 101 269.01210 428.712 88.50010 "BSCK A102"
    ! DATE: 12/17/12, TIME: 13:51:19.000
    PRISM  4.905
    PRISM  4.875
    PRISM  4.905
    PRISM  4.875
    PRISM  4.905
    F1 VA 110 173.42390 373.490 91.18165 "FD BM1401871 CP"
    BS  101 0.00000
    PRISM  4.875
    PRISM  4.905
    PRISM  4.875
    PRISM  4.905
    F1 VA 111 90.58390 342.308 88.03170 "FD 4PMMH CP"
    ! TARGET PRISM,     HR:1.591 (1.591 + 0.000 OFFSET), PRISM CONST.:0.000MM
    Active Contributor
    12-21-2012 04:48 PM in reply to: RandyBenson
    I did finally get a solution, using the following:
    Initial Station: 101
    Initial Backsight: 38
    Stations: 106,113,120,121,102
    Final Foresight: 101
    However, I don't see some of the redundant shots in the .LSI file, probably because we can't use the same point numbers in the data collector file:
    !                    Least Squares Input File
    !                      Generated By Survey
    !      Point       Northing        Easting      Elevation
     NEZ      38    4277.411000    4791.104000      90.660000
     NEZ     101    5000.000000    5000.000000     100.000000
    ?NEZ     106    5222.663432    5097.127365     104.607356
    ?NEZ     113    5127.980464    5404.889410     119.576089
    ?NEZ     120    4853.871179    5320.602915     120.491150
    ?NEZ     121    4487.644441    5207.991065     102.858636
    ?NEZ     102    4588.228149    4880.993018      90.651677
    !    From    At     To                                     Angle    Distance
    !   Point  Point  Point           Angle       Distance   Std Error Std Error
    AZ           101     38       196.07273                   0.00100
    SD           121    102                        342.335                 0.007
    VA           121    102        92.02380                   0.00056
    A     120    121    102       270.00195                   0.00064
    SD           101    106                        242.968                 0.007
    VA           101    106        88.54494                   0.00055
    A      38    101    106       187.26345                   0.00070
    SD           102    101                        428.725                 0.007
    VA           102    101        88.45028                   0.00036
    A     121    102    101       269.01210                   0.00061
    SD           120    121                        383.556                 0.007
    VA           120    121        92.38074                   0.00060
    A     113    120    121       179.59575                   0.00082
    SD           113    120                        286.778                 0.007
    VA           113    120        89.49024                   0.00038
    A     106    113    120       269.59270                   0.00075
    SD           106    113                        322.346                 0.007
    VA           106    113        87.20205                   0.00071
    A     101    106    113       263.31585                   0.00084
    Can I pad them into this input file in the above format, changing the point numbers of the redundant shots and then click 'Process Input File' and have it apply least squares to _all_ my observations?
    Valued Contributor
    12-21-2012 05:04 PM in reply to: RandyBenson
    Yes, you should change the redundant point numbers to the correct point number and re-run the file.
    If you have multiple points, you may be able to change them in the raw file and get it to recognize it.  (save the original raw file though).  And to do the least squares adjustment, you will need to create an input file.
    It should work fine, except you do not have a definite tie to point 38, your original control point.
    Surveyor Lee
    Active Contributor
    12-29-2012 03:13 PM in reply to: SurveyorLee
    Thanks for replying and apologies for my delay in responding - I've been on vacation. (Woo Hoo!)
    <It should work fine, except you do not have a definite tie to point 38, your original control point.>
    Then I'm still missing something fundamental. Point 38 is a _copy_ of point 102. It is only there because I need a backsight direction to the leg of the control traverse between point 101 and point 102 or the routine throws an error. I don't want to use 102 as an initial control point because my understanding is that control points don't get adjusted, and 102 is part of my control traverse loop. I need it to be adjusted with all the other control traverse points.
    Valued Contributor
    12-29-2012 05:40 PM in reply to: RandyBenson
    Let me digress a little to be sure I understand this.
    From point 38 (102) you have a traverse and you need it adjusted.
    Based on the cropped portion of the field book you posted, you have a fixed azimuth between 38 and 101 and fixed coordinates.  Have you performed a manual inverse to be sure the coordinates will match the azimuth.  If not, that could be the cause of the trouble.
    The entry in the top of the field book you posted reads:
    HORIZ ANGLE RIGHT
    VERT ANGLE ZENITH
    AZ 101 38 259.04510
    The last line "AZ 101 38 259.04510" is fixing the azimuth between 38 and 101 to the az.
    THe "nez" fixes the coordinates. on the points.
    IF you want to hold th az between 38 and 101, you can change all of the calls for 102 to 38.  Since 38 is a know points, leave the NEZ on it as it is.
    on the "NEZ 101......", change to ?NEZ
    Leave the Az 101 38...., but you may want to change it by 180 degrees and make it AZ 38 101, since you are holding 38 fixed.  This will hold the azimuth but let 102 move in distance from 38.
    From looking at the least squares input file pt 38 and 102 are not the same
    As you can see, the preliminary coordinates on 102 are quite different than 38.
    Also the az 101 to 38 is quite different too.
    These two issues have to be resolved first. When they are resolved, most of the rest of the traverse will fall into place.
    Surveyor Lee
    Active Contributor
    12-30-2012 09:55 AM in reply to: SurveyorLee
    <looking at the least squares input file pt 38 and 102 are not the same>
    You're absolutely right -- I completely ignored the azimuth between them. I've gotten in a bad habit from programming a similar routine (minus the least squares) that derives the azimuth by inversing between the coordinate pairs coded to the point numbers.
    I'll fix that, and then I need to reformat, re-point-number and insert all my redundant shots into the least squares input file and re-run it.
    Thanks for your help!
