• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Transparent lines or hatched objects.
    354 Views, 1 Replies
    09-15-2009 03:55 PM
    Is it possible to make a very thick line or small hatched object transparent so you can see the raster image underneath? I'm using Civil 3D 2008.
    Thanks in advance.
    Chris
    Please use plain text.
    Active Member
    Re: Transparent lines or hatched objects.
    09-16-2009 08:09 AM in reply to: witster23
    No, this is not possible.
    However, instead of using a solid hatch which is completely opaque, use something like a net(ANSI37) hatching.
    Not quite transparent but, you will be able to see through a bit more
    Charles
    http://cadtv.spaces.live.com
