• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Transition (spiral) shift offsets
    73 Views, 1 Replies
    11-30-2012 04:30 AM
    I'm looking for a way to determine (and preferably edit) the values of P1 and P2, the offsets of the initial tangents into the PC/PT of the shifted curve. I've searched the forum and the help, and it's not in the (admiteddly basic) book I have either. Does anyone have any ideas, please?
    [Edit: OK, after double-checking,I just found Widening offset clothoid, but I'm still none the wiser.]
    Please use plain text.
    Employee
    Re: Transition (spiral) shift offsets
    11-30-2012 01:36 PM in reply to: trevj
    In the Alignment Grid View you can add a column to display P. The value is read only, but adjusting the length of the spiral will adjust the P value.
    The P value can also be added to spiral and tangent intersection labels.
    Peter Funk
    Peter Funk
