• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Contributor
    Accepted Solution
    Transition between two corridors
    371 Views, 9 Replies
    09-24-2012 07:31 PM
    I'm designing a single 2% cross flow blke path. I wanted to reverse the cross flow so I created two
    corridors, one flowing to the left and one flowing to the right along the same tangent centerline. I want to
    add a 50 foot warp transition in between them. I'n not sure how to do that. I thought of the intersection
    design but that won't work. Any suggestions?
    Thanks John Wilson
    Please use plain text.
    *Expert Elite*
    sboon
    Re: Transition between two corridors
    09-24-2012 09:00 PM in reply to: johnwilson0805
    Rather than try to transition between two corridors you could just create a single one that does the whole job.
    *Expert Elite*
    09-24-2012 09:06 PM in reply to: johnwilson0805
    You'll need to use a subassembly that supports superelevation. Then I would create a superelevation view to make the required changes. Look it up in help if you don't know how that's done.
    Matt Kolberg
    Cansel - Autodesk Division
    http://www.cansel.ca/
    *Expert Elite*
    sboon
    09-24-2012 09:35 PM in reply to: mathewk
    Or you could try this drawing instead....
    Active Contributor
    09-25-2012 06:57 AM in reply to: sboon
    Thanks Steve
    I'll look into that
    JOhn
    Active Contributor
    09-25-2012 06:59 AM in reply to: mathewk
    Hi Matt
      I thougth of that. I'll check it out
    Thanks John
    Active Contributor
    09-25-2012 07:02 AM in reply to: sboon
    Thanks Steve for the drawing
    I'll look at it and work with it. If I have further question I'll post it
    Thanks again
    Active Contributor
    10-03-2012 08:45 AM in reply to: sboon
    Hii Steve
    Thanks for the sample drawing "CORRIDOR-3A" . Thats perfect for what I need to do for
    my bike path design. The Engineers want me to set manual stations and just flip flop the 2% cross slopes.
    Heres my question:
    In my drawing when I go to SUPERELVATION tab and then "CALCULATE/EDIT SUPERELEVATION", the program
    calculates for me per ASSHTO 2001 elmax 4% around curves only. Then I create from
    "CREATE SUPERELVELATION VIEW"  a view but it looks totally different from your sample drawing. (I'm
    using 2012)
    Would it be possible to give me a step by step instruction on how you arrived at the view that you showed?
    The tutorials doesn't explain these steps
    Thank you for your help so far
    John Wilson
    *Expert Elite*
    sboon
    10-03-2012 09:30 AM in reply to: johnwilson0805
    Avoid the calculator and go straight into the Tabular editor.  Delete all of the super data and then start fresh, adding manual stations.  I recommend that you first set the defaults for the two ends of your alignment, then work inward to the section that you're going to be editing.
    The table isn't easy to follow at times, so I like to have a superelevation view to help visualize what is happening.
    Active Contributor
    10-03-2012 12:19 PM in reply to: johnwilson0805
    Hi Stevw
    Thats great. That makes it easy for me
    John
