Solved by Neilw_05. Go to Solution.
Solved by Civil3DReminders_com. Go to Solution.
I'm trying to do the same thing - gradual transition from a crowned roadway to one with superelevation, along a curve. Leaving a gap connects the two regions with straight lines. How do I get the transition to follow along the curve of the alignment?
Thanks!
My suggestion was predicated on the region being straight and no vertical curve.
In a curve you probably should use super elevation. I never bother myself since most of the work I do would require any SE. But I have used the caveman method to do a transition every so often.
create your corridor with the two assemblies and leave a gap the length you want to transition
Then create a profile from the eop feature line of corridor
the profile will more than likely come in broken due to the gap in the corridor - no matter - use it to develop the eop profile. If there is a gap, all the better, connecting the two will give you the transition rate over L to get to 2%. Same process for the other side.
Once you are done you no longer need the 2% assembly - run the normal crown the whole way and target the eop profiles developed from the first run. Note in the region of the curve(s) you will want to make frequency closer. This thesis also assumes you are using a outsideSuper pavement sub or any that will let you target the ETW
Joe Bouza
You can also achieve the transition by means of a featureline snapped to the ends of the assemblies on the ends of the transition. It can be a curved featureline or polyline, but a featureline should automatically adjust to the elevations of the corridor when edited. Use the featureline as a vertical target for the corridor assembly through the transition, making sure the assembly can follow a target..
Try making an assembly for the transition that has marked points placed on the ends of a linkwidthandslope to target the ETW L&R. The linkwidthandslope should be configured to not display the link so only the marked points connect.
John Mayo
How do you target the ETW? There is nothing there to target? I have a case where I have an inverted crown transitioning to a typical crowned road. It's difficult because the alignment is on a curve that goes into a reverse curve so just leaving a gap between assemblies doesn't do it.
