• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Member
    Toolspace problems in C3D 2012
    753 Views, 13 Replies
    04-06-2012 11:22 AM
    I am having a problem with what I believe to be the toolspace palette. When I have it expanded and docked on the left side of the screen, at a certain point (timeline varies) it copies it appears to copy itself directly above itself and throws an error of:
    FATAL ERROR:  Unhandled e06d7363h Exception at fd5ccacdh.
    and closes the program.
    At that point it does something to my Excel program and won't let me copy/paste anything.
    This is all on a new computer that I've had for about a week, so I'm not sure if it's the video driver or where it's coming from. All of the drivers are up to date.
    Please Help!!
    Civil 3D 2012 SP1
    Windows 7 x64 Pro
    AMD (ATI) Firepro M8900 (FireGL) Mobility Graphics
    8 GB Ram
    Intel Core i5-2520M CPM @ 2.50 GHz
    Please use plain text.
    Valued Mentor
    owenmull
    Re: Toolspace problems in C3D 2012
    04-06-2012 11:29 AM in reply to: pbrucer2
    The only solution I have found to work for this type of error is to edit the registry key.
    Go to Start-->Run-->type 'regedit' and navigate to the following:
    (If 'Run' command not on Start menu, Google how to bring it up, or reply to me)
    [HKEY_CURRENT_USER\Software\autodesk\AutoCAD\R18.0\ACAD-8000:409\WebServices\CommunicationCenter]
    "LastUpdateTimeLoWord"=dword:4be447d0
    Changing the dword to 00000000 solves the problem.
    This is the only solution I have found to work. Autodesk will tell you to check for updates, and run repair, but these dont work for this issue.
    Warning: Typical Registry warnings apply.     <-------Obligatory Statement.
    -Owen
    Windows 7 x 64 bit
    ATI FirePro V4800 Triple Monitor
    12 GB RAM
    Intel Xeon W3550 @ 3.07 GHz
    Civil 3D 2012 SP 2
    ______________________________________________________________
    Intel inside. Idiot outside.
    Usually, I find that the problem is between the keyboard and the chair.
    Active Member
    04-06-2012 02:28 PM in reply to: pbrucer2
    -owenmull,
    I made the change that you suggested and It did it again.  Ses attached Pic.
    If you look close under the second command line from the bottom (line that has _mtedit), the toolspace copies itself and covers the ribbon and toolbars right after it faults. You don't see any of the toolbars or the ribbon in that area. Luckily it wasn't a fatal fault this time and I was able to save the file.
    Anyone have any ideas?
    Civil 3D 2012 SP1
    Windows 7 x64 Pro
    8 GB Ram
    Valued Mentor
    owenmull
    04-06-2012 03:17 PM in reply to: pbrucer2
    Hmmm, I'm not sure on this one. Could be a video card issue, I know some of ATI's "mobility" line never used to like Cad programs very much, but I can't say with any degree of certainty. May want to contact Autodesk about this one.
    -Owen
    Windows 7 x 64 bit
    12 GB RAM
    Civil 3D 2012 SP 2
    Valued Mentor
    owenmull
    04-09-2012 09:39 AM in reply to: pbrucer2
    Try this:
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17751015&linkID=9240698
    -Owen
    Windows 7 x 64 bit
    12 GB RAM
    Civil 3D 2012 SP 2
    Active Member
    04-09-2012 10:54 AM in reply to: owenmull
    That hotfix did not work.  I got a better screen print of the fault this time though. Please see attachment.
    Civil 3D 2012 SP1
    Windows 7 x64 Pro
    8 GB Ram
    Valued Mentor
    owenmull
    04-09-2012 11:55 AM in reply to: pbrucer2
    The only thing I can think of that may be left would be to repair/reinstall.
    Looks like a video card issue to me.
    Sorry I couldnt be of more help.
    -Owen
    Windows 7 x 64 bit
    12 GB RAM
    Civil 3D 2012 SP 2
    Active Member
    04-09-2012 11:59 AM in reply to: owenmull
    Yes I've done a complete uninstall/reinstall with the same results.  I'm of the same opinion about the video card being the problem. I truly appreciate your help on this.
    Civil 3D 2012 SP1
    Windows 7 x64 Pro
    8 GB Ram
    Employee
    04-12-2012 11:31 AM in reply to: pbrucer2
    Hi pbrucer2,
    Once the clean user registry do not solves your problem, these errors may indicate a corruption of the Microsoft® .NET Framework. This operating system component is required for several AutoCAD features, including the Properties Palette, Layer Manager, Ribbon, Menu Browser, Tooltips and other features.
    So, I suggest you to reinstall the Microsoft .NET 4.0 on your machine and then perform a Repair your AutoCAD Civil 3D (http://usa.autodesk.com/getdoc/id=TS16436702).
    If this suggestion still do not solve your problem so your machine can present some Conflicting Apps.
    To check this possibility, try to run the AutoCAD Civil 3D 2012 with Windows in Diagnostic Mode (http://usa.autodesk.com/getdoc/id=TS1054234) following the steps as described below:
    "Using the Windows System Configuration Utility to make a diagnosis:
    1) In the 'Start' menu (Windows), click 'Run'.
    2) In the 'Open', type 'msconfig' and click 'OK'.
    3) Click on the 'Services' at the top.
    4) At the bottom (just above the OK button), click the check box Hide all Microsoft services.
    5) Click on 'Disable all'.
    6) IMPORTANT: In the list, check 'Autodesk Licensing Service' selected as active.
    7) Click on the 'Startup'. If there is a mix of items marked / unmarked, make a list of elements. Then click on 'Disable All'.
    8) Click OK and restart Windows when prompted (click on 'OK' on any error that you can get permission.)
    9) After restarting, click 'OK' to warning dialog box MSCONFIG.
    If AutoCAD Civil 3D is running well at this point, then there is an interaction with any other service or application that is taking the behavior problem (in the normal startup mode). Using lists of check boxes in MSCONFIG tabs 'Services' and 'Startup', (created at step 7) you can use a process of elimination to discover what element(s) is(are) causing the problem.
    Please, let me know if these suggestions helps you.
    Naty
    Natanielly Rofner
    Product Support Specialist
    Autodesk Global Subscription and Support
    Autodesk, Inc.
    Distinguished Contributor
    04-26-2012 10:45 AM in reply to: pbrucer2
    Did you find an answer to your problem?  A similar thing just happened to one of my machines.  If I turn off the toolspace the problem goes away.
    Thanks.
