• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Member
    mal5141
    Toolspace error
    404 Views, 4 Replies
    01-11-2011 01:41 PM
    Everytime I click on the toolspace icon on the ribbon, a message saying "FATAL ERROR: Unhandled Access Violation Reading 0x0000 Exception at dbdb872bh" comes up. A new window then shows up asking about sending an error report. Does anyone know what is going on here?
    I included an attachment so that you can have an idea of what is going on
    Please use plain text.
    Valued Mentor
    Re: Toolspace error
    01-11-2011 02:50 PM in reply to: mal5141
    First thing - what version and if you go under "help -> about" what version number does it say?
    Let's see if you have the current service packs applied.
    Re: Toolspace error
    01-11-2011 03:23 PM in reply to: mal5141
    That's very odd.  Sounds like an installation issue.  Try a repair, if that doesn't work, remove it and reinstall it.
    One other thing you can try, if you're comfortable with editing the registry:
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13288548&linkID=9240697
    The HKEY in that article is for 2010, you'll have to edit the key for 2011.
    Matt Kolberg
    Cansel - Autodesk Division
    http://www.cansel.ca/
    Member
    mal5141
    Re: Toolspace error
    01-12-2011 10:58 AM in reply to: tzzzzoddhepworth4253
    Hey,
    I am using AutoCAD Civil 3D 2011 Version 8.0.1439.2
    I hope this helps
    Valued Mentor
    Re: Toolspace error
    01-12-2011 11:59 AM in reply to: mal5141
    Not quite what I expected on the version - I get Product Version: E.116.N.0, AutoCAD Civil3D Version 2 - indicating that I've applied Service Pack 1
    I suppose it might have been easier if I asked "have you applied the latest service pack...."
    If it doesn't say "Version 2" then you probably don't have the service pack applied.  I'd try that first.
