AutoCAD Civil 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Re: Toolspace Item View not working properly
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I change the registry. It worked until I try to sort the column then it goes blank. This is a bug!
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I don't think anyone is disputing the fact that it's a bug. The "fix" simply fixes the display problem......until you try and sort again, hence the last line in my earlier reply
R.K. McSwain
CADpanacea.com | twitter | Cadalyst Tips
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I was having the same troubles, and "Fix" worked. I don't even mind having to reload the lisp when I accidentally hit the "sort" button, because it's better than not having the list.
Thank you!
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Had the same problem! Cut and pasted the reg values for the imperial to the metric reg values and it seems to work.
(Imperial)
AeccMgrParcel:List:AeccMgrPltProspector
rospector
3;-1;9;1;0;0;1;0;0,100,1;1,60,1;2,100,1;3,90,1;4,7
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
FIX works to view the parcels, but still does not resolve the column sort issue which causes them to disappear again and again and again?
mathewk wrote:This fix is great, but still a bit of a pain. i have created a LISP routine you can run that fixes this. See attached.
This command is FIX.
When the bug happens, run this command, click to somewhere else in the prospector then click on Parcels again and you should see the populated list.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Sort
Run the FIX routine
Every time you sort
Cansel - Autodesk Division
http://www.cansel.ca/
