• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Contributor
    Re: Toolspace Item View not working properly
    02-11-2013 05:20 AM in reply to: tjhootman
    I change the registry. It worked until I try to sort the column then it goes blank. This is a bug!
    Please use plain text.
    *Expert Elite*
    rkmcswain
    02-11-2013 08:34 AM in reply to: kclark138
    I don't think anyone is disputing the fact that it's a bug. The "fix" simply fixes the display problem......until you try and sort again, hence the last line in my earlier reply
    03-20-2013 09:34 AM in reply to: mathewk
    I was having the same troubles, and "Fix" worked. I don't even mind having to reload the lisp when I accidentally hit the "sort" button, because it's better than not having the list.
    Thank you!
    Member
    jpierce8
    04-05-2013 03:19 PM in reply to: rkmcswain
    Had the same problem!  Cut and pasted the reg values for the imperial to the metric reg values and it seems to work.
    (Imperial)
    AeccMgrParcel:List:AeccMgrPltProspector:smileytongue:rospector
    3;-1;9;1;0;0;1;0;0,100,1;1,60,1;2,100,1;3,90,1;4,70,1;5,100,1;6,100,1;7,100,1;8,100,1;
    Member
    jpierce8
    04-05-2013 04:37 PM in reply to: mathewk
    FIX works to view the parcels, but still does not resolve the column sort issue which causes them to disappear again and again and again?
    mathewk wrote:
    This fix is great, but still a bit of a pain.  i have created a LISP routine you can run that fixes this.  See attached.
    This command is FIX.
    When the bug happens, run this command, click to somewhere else in the prospector then click on Parcels again and you should see the populated list.
    *Expert Elite*
    04-05-2013 04:44 PM in reply to: tjhootman
    I know, the procedure is:
    Sort
    Run the FIX routine
    Every time you sort
    Matt Kolberg
    Cansel - Autodesk Division
    http://www.cansel.ca/
