AutoCAD Civil 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Title Blocks - Insert vs. XREF in Paper Space
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I'd like feedback as to whether you "Insert" or "XERF" your title blocks into paper space for setting up sheets. What are the compelling arguments either way?
Re: Title Blocks - Insert vs. XREF in Paper Space
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
If the title block is shared across multiple files then you'll want to use an XREF. If within a single file then a block works fine.
If you have any reason to expect the project will evolve into multiple files for certain drawing sets then you'd save yourself a lot of re-work to start with XREF'd borders and title blocks.
Infrastructure Suite/C3D 2013, LDT 2004, Power Civil v8i SS1
WIN 7 64 PRO
HP Pavillion h8xt, i7 2600, 12 GB
RADEON 6450, 1 GB
http://www.sec-landmgt.com
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
We have a very fixed, static title block and border, so we insert it as a block into each sheet, but the Project Name, Sheet Numbers, etc. are inserted using Fields so we can update them via the Sheet Set Manager. It works well for us.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
In theory, when the title block is an XREF the linework (e.g. company logo) can be udpated in one location without needing to update all drawings. You would still need a block insert to handle the attributes though. But there are a few short-comings with that method. Radical changes to the appearace will require changing the inserted block with attributes on every drawings anyways. You also need to handle legacy drawings as well - does that old drawing point to the right XREF? If the XREF contents have changed but the file is still in the same place, the legacy drawing won't look the same as it was officially issued.
Almost all of our clients use straight-up block inserts. One uses the XREF + insert scheme.
Adopt. Adapt. Overcome. Or be overcome.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
In 13 years of drafting I have had to change the title bloick maybe once for a whole project mid-stream
I also have dynamic block properties in many of my title blocks which would not work with xrefs.
Cansel - Autodesk Division
http://www.cansel.ca/
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I've never used the Xref method but the Insert method works well for me as I have populated the block with field attributes/properties for use in Sheet Set Manager
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2014, Civil 3D 2013 (UKIE) Hotfix 3; Win 7 Pro x64
256Gb SSD, 300Gb 15,000 rpm HDD
16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
We use a combination of both. Anything that appears on every sheet is in a drawing that is xrefed. All the components that are unique to each sheet are inserted as a block. The block contains attributes, which may have fields referencing sheet set properties.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Land Consultants
Civil3D 2012 (Service Pack 2.1)
Windows 7, 64 bit
Intel i7 2600 @ 3.40Ghz
16 GB RAM
Nvidia Quadro 600
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Our "Title Block" is just linework. So we don't insert or x-ref. It's drawn in a template drawing and we just insert a layout from template, so all the linework is there.
We have Mtext with fields to reference Sheet Set data. These are easier to deal with than blocks in the half of our projects that don't use sheet sets; we can just edit the Mtext, delete the field and write what we need.
Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
__________________________________________________________
Credit where credit is due! Give kudos or accept as solution whenever you can.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
we do both block and xref. xref in the title block linework, project name, date, job number, drafter, etc. block in sheet title, page number, etc. once it's all set up in your drawing templates it's easy peasy. it's sucks having to change the date manually on 100 sheets.
Intel Core i7 CPU 930 @ 2.8GHz
12GB Ram
64 bit
C3D 2012 SP2
