• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Contributor gk
    Accepted Solution
    Tin Surface question
    211 Views, 2 Replies
    10-20-2012 03:12 PM
    I have set up the linework code set and the figure prefix database where I noted which figures were to be breaklines. I then imported the ASCII coordinate final to the survey database, processing the linework as it is imported. I create a surface then modify the surface by importing a point group and create a tin, but the figures in the drawing are not being recognized as breaklines.......what am I doing wrong ?
    Garry
    Please use plain text.
    *Expert Elite*
    Re: Tin Surface question
    10-21-2012 01:05 AM in reply to: gk
    Hard to say...  C3D has LOTS of settings that can create a problem.
    But my first guess is that you didn't select the breaklines in the Survey Database and do Right cliick->"Insert Breaklines".  If you've already tried that, and it fails, then it's probably a settitng in your Desc Keys, your Figure Prefix Lib, or your Styles/Layers.
    Sinc
    Contributor gk
    10-22-2012 05:03 AM in reply to: gk
    Thank you, Sinc - that was my problem. I've checked out the help files and gone through the process again. I understand now how it works.
    Garry
