• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Valued Contributor
    taneum
    Tieing Into Existing Berm
    268 Views, 23 Replies
    12-12-2012 09:23 AM
    This is a real doozy my boss wants done.  We have and existing sewer lagoon with 4:1 side slopes.  We are designing a bypass pipe outside of the 4:1 side slope but because of cover issues, we need to add some dirt to the side slope to fill above the pipe.  He wants to continue that 4:1 side slope up until it matches the profile elevation abaove the pipe.  Once that happens, then grade a 12' wide berm with 2% crown each way and then come back down the other side at a 4:1 until it matches existing grade.  We drew a target line at the tope of the existing 4:1 on the existing ground and used that as a start point.
    Here is the problem, we are using the "linkwidthandslope" sub-assembly, how do we tell it to go up at a 4:1 until it matches our design profile grade?  Horizontally, that right side of the sub-assembly wil be different in every cross section,but vertically it needs to match the profile.  The left side of the sub-assembly is working okay and tieing in at the top of the existing 4:1 slope.  The right side of the sub-assembly though is tieing in at the design profile grade vertically and at the alignment centerline horizontally.  When this happens, my slopes all differ and they cant, they need to go up at a 4:1 so the existing 4:1 slope continues going up.
    Does this make sense to anyone?  Its a tough one.
    Attached are some pictures.
    Please use plain text.
    *Expert Elite*
    Re: Tieing Into Existing Berm
    12-12-2012 09:30 AM in reply to: taneum
    Having some trouble following, I think more pictures might help.
    Isn't it possible to give a target profile without targeting an alignment?  Use a link at a specified slope (4:1) targeting the design profile.
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
    Valued Contributor
    taneum
    12-12-2012 09:37 AM in reply to: troma
    I have targets set up to a feature line in which the left side of the sub-assembly ties into.  This is at the top of the existing berm.  The problem is, why does the right side of the sub-assembly autommatically tie into the profile design grade?  Is the "linkwidthandslope" sub-assembly the wrong one to be using?
    *Expert Elite*
    12-12-2012 10:24 AM in reply to: taneum
    It looks to me as if you have a slight crown (2%?) and then the right side is targeting the surface at 4:1. Is that not what's happening?  It looks like it starts at the bottom of that 2% and then targets the surface. What do you want it to do?
    In your first message, here is an intersting line:
    "He wants to continue that 4:1 side slope up until it matches the profile elevation abaove the pipe."
    So, you want to start at the existing top of 4:1 slope (horizontal and vertical requirement)
    You want to end at the profile elevation (vertical requirement)
    You want to end above the pipe (horizontal requirement)
    It sounds like you have horizontal and vertical requirements for the bottom and top of this slope, so how can you also give it a slope requirement (4:1)?  Unless you give the top the freedom to move horizontally so as to be not above the pipe, it can't calculate the slope.
    Valued Mentor
    LisaPohlmeyer
    12-12-2012 11:09 AM in reply to: taneum
    How about a LinkSlopeToElevation link instead?
    Lisa Pohlmeyer
    Williamson Co. Dept. of Infrastructure
    Intel i7 3.33Ghz, 16Gb RAM
    Nvidia Quadro 2000D
    C3D 2012 SP3, C3D 2014
    Win 7-64
    Please mark this as the solution if it resolves your issue.
    Valued Contributor
    taneum
    12-12-2012 12:23 PM in reply to: LisaPohlmeyer
    Troma laid it out correctly.  Yes, I want to continue that existing 4:1 slope up on the left side until it matches the elevation of my design profile.  With that being said, the horizontal location of where that 4:1 slope will stop varies because my design profile drops at 0.570%.  If you look at the .pdf I attached earlier, you can see that the red dot where it is supposed to stop is actually right of the centerline.  The offset at which it stops though in each cross section will vary since the existing top of the 4:1 slope varies in distance from my alignment centerline.
    Lisa, good thought but the "linkslopetoelevation" want a constant elevation to project up to.  In my case, the 4:1 slope needs to continue project up until it meets the design profile elevation at that particular cross section.
    Once that happens, I will then attach "linkwidthandslope" sub-assemblies to creat a 12' wide berm and then tie back into the existing grade.
    The right side is working fine.
    If you can picture this correctly, when it works, the new pipe (which is down the center of my alignment) will run somewhere under the 4:1 side slope that is being continued up.  The center of my new berm will float from left to right over the pipe and alignment centerline.
    Valued Contributor
    taneum
    12-12-2012 12:44 PM in reply to: taneum
    How are the targets programmed to work?  Does it assume that if your sub-assembly is on the left side of the baseline that the left point code of the sub-assembly is what gets targeted to your target lines and vice versa, if your sub-assembly is on the right side of the baseline then the right point code of the sub-assembly gets targeted to your target lines?
    Thats what it is doing in this case, the left side of my "linkwidthandslope" sub-assembly is targeting my target line which is good but the right point code just defaults to the design profile elevation at centerline.  I really want that right point code to keep going up at a 4:1 to the same elevation of the profile.
    *Expert Elite*
    12-12-2012 01:26 PM in reply to: taneum
    As I understand it, the whole assembly needs an alignment & profile to start from.  It can then target other alignments & profiles as necessary, or not.  If the one point that is absolutely concrete is the top of the existing berm, you need an alignment and profile running exactly along the top of berm.  (Alignment tracing the top of berm, profile from surface.)  That should be the anchor point of your assembly.  You will need to target the other profile with a 4:1 slope for starters, then put your 2% crown, then matching existing the other side.
    If you use the pipe alignment as the anchor point it can't work, because it is anchored horizontally to that location.
    Valued Mentor
    fcernst
    12-12-2012 01:30 PM in reply to: taneum
    You could do it piecewise.
    You first goal is to find the meandering alignment for the red dot,  located vertically at the desired pipe cover profile elevation, correct?
    1. Run a flat and wide, all encompassing reference surface using the desired pipe cover Profile.
    2. Run an assembly with 4:1 daylight attached along the exisitng toe alignment and profile, that daylights up to your reference surface.
    3. Now you have located your meandering red dot alignment and profile to build the 12' berm off of.
    Ernst Engineering
    Fred Ernst, PE
    C3D 2013 SP1, C3D 2014
    W7x64; i7 8gb; Radeon HD 5700
    www.ernstengineering.com
    *Expert Elite*
    12-12-2012 01:36 PM in reply to: fcernst
    Fred, it's simpler than that.  It's just a matter of priorities.  You need to build the assembly with the same priorities as you want the berm to have.
    1. You start from the top of existing berm.
    2. Go up at 4:1 until you hit the profile elevation.  (you may have to superimpose the design profile onto the profile view of the 'top of berm' alignment)
    3. Go up at 2% whatever distance.
    4. Go down at 2% whatever distance.
    5. Go down at 4:1 until you hit the existing ground.
