• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Member
    Tie Distances?
    165 Views, 9 Replies
    03-17-2013 06:17 AM
    I am using AutoCad C3D. I have drawn a building and now I am trying to position the building on a plot with uneven property lines using only “tie distances” from the spots on the property to specific spots of the building.
    I do not know which C3D program functions (with just distances known) to get the building placed properly on the plot. Help! Thx
    Please use plain text.
    *Expert Elite*
    antoniovinci
    Re: Tie Distances?
    03-17-2013 06:24 AM in reply to: poolshark333
    Did you just try the _ALIGN command..?
    Member
    Re: Tie Distances?
    03-17-2013 06:34 AM in reply to: antoniovinci
    I have 5 tie lines; can I use _Align to enter all 5? How do I select/enter them all together so all 5 constraints are met?
    *Expert Elite*
    Joe-Bouza
    Re: Tie Distances?
    03-17-2013 06:39 AM in reply to: poolshark333
    I don't know if align has a limit to source/ destination, but 5 offsets should give sufficent layout to place the building
    Thank you
    Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
    HP Z210 Workstation
    Intel Xeon CPU E31240 @ 3.30 Hz
    12 GB Ram
    Note: Its all Resistentialism, so keep calm and carry on
    64 Bit Win7 OS
    Valued Contributor
    Re: Tie Distances?
    03-17-2013 11:29 AM in reply to: poolshark333
    If you have drawn the building and the dimensions on it are fixed, all that should be neeeded is to determine two points on the site using the offset command from the property lines. When you use the Align command to those two points you can see how the other points match.  With fixed geometry for the builidng, you may be  able to shift the building to better match some of the tie distances, but will probably not be able to match all of them.
    Surveyor Lee
    Member
    Re: Tie Distances?
    03-17-2013 01:12 PM in reply to: SurveyorLee
    I have a fixed building and the building site. I need to position the building onto the site and satisfy the 5 tie distances. I have not yet dropped the tie points onto the building nor site. That's where I'm stuck. I've attached a sketch.
    *Expert Elite*
    Joe-Bouza
    Re: Tie Distances?
    03-17-2013 03:42 PM in reply to: poolshark333
    What seems to be the problem?
    Presumably there are dimensions along the building where those tie line intersect. What have you tried?
    post a drawing.
    Thank you
    HP Z210 Workstation
    12 GB Ram
    64 Bit Win7 OS
    *Expert Elite*
    Re: Tie Distances?
    03-18-2013 06:09 AM in reply to: poolshark333
    Surely this is not located to Rocket Science accuracy.  From your picture it appears a rectangle.   Draw a closed polyline to the dimensions of the building and and drag it around until it works.
    Bill
    *Expert Elite*
    Re: Tie Distances?
    03-18-2013 07:16 AM in reply to: poolshark333
    Most of these questions can be reduced back to simply: what would you do if it was on paper?  Answer: draw an arc from the tie point at the radius of the tie, offset a parallel line at the required distance.
    I'd use the circle and offset commands and find some intersections.
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
    *Expert Elite*
    AllenJessup
    Re: Tie Distances?
    03-18-2013 07:27 AM in reply to: troma
    Yes. Circles is what I'd use. I can't see why anyone would tie off a house like that. But if I had that info to work with that's what I'd do. It looks like the 2 ties in front may be parallel to that property line. So that's where I'd start.
    Allen Jessup
