• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Member
    Text orient from xref
    304 Views, 6 Replies
    05-17-2011 01:40 PM
    I have created a base plan that has lot numbers for a subdivision.  I have created the text style to align with the viewport orientation and it all works correctly.   I would like to xref that base plan into other blowup sheets and have the lot numbers scale and reorient to the new respective viewport.   The lots scale correctly but do not reorient, any ideas.
    Please use plain text.
    *Expert Elite*
    Re: Text orient from xref
    05-17-2011 01:48 PM in reply to: cmhguy01
    Do you have the Orientation Reference set to VIEW?
    Bill
    Active Member
    05-17-2011 01:50 PM in reply to: wfberry
    Where do you find that?  It sounds good.
    *Expert Elite*
    05-17-2011 02:41 PM in reply to: cmhguy01
    It's in the Style setting.
    Unfortunately, I have not found this setting to work through XREFs...  :smileysad:
    Sinc
    05-18-2011 06:04 AM in reply to: cmhguy01
    Location to set the orientation reference for label styles.  And it does work from an XREF. See the second image. The parcel drawing was referenced and the UCS for that viewport was changed. Worked perfectly.
    Active Member
    05-18-2011 06:09 AM in reply to: cmhguy01
    I did get it to work.  I just didn't get into a viewport in the linked drawing to see that it would rotate through the viewport but not in Modelspace.  Thanks.
    Active Contributor
    10-13-2011 12:37 PM in reply to: cmhguy01
    Hi all,
    I have been having a similar issue with MLEADERS.
    Is there a way to have a MLEADER in a base file rotate to be plan readable in an XREF file's ritated viewport?
    We typically use MLEADERS not notes/labels.
    thanks for any help.......
