• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    *Breslin, Kevin
    Text Component Editor will not take changes
    181 Views, 2 Replies
    10-06-2003 05:24 AM
    Sometimes if I create a new point label style I can change settings such as
    "Precision" but most of the time I cannot get the change to stick. For
    example, creating a new point label style in a new drawing created from the
    Metric by style prot where I wish to change the Precision, the dialog will
    appear that it will take the change but if you save and go back and check
    the settings you will see that the change did not stick. I've checked in
    the drawings "Label Style Defaults" and nothing is locked. How do you get
    the changes to stick? Is this a bug or is there another device locking
    these settings but is not graying out the locked fields?
    Kevin Breslin
    Please use plain text.
    *Breslin, Kevin
    Re: Text Component Editor will not take changes
    10-06-2003 05:34 AM in reply to: *Breslin, Kevin
    Note: I did find that if you replace the formatted text rather than editing
    it will work. So either there is an editing bug or the interface needs to
    properly represent the existing text as read only.
    Kevin Breslin
    "Kevin Breslin" wrote in message
    news:2D89CF1B642D3204AEE73C42A0B7CE3F@in.WebX.maYIadrTaRb...
    as
    the
    > Kevin Breslin
    *Philbrick, Daniel
    Re:
    10-06-2003 09:58 PM in reply to: *Breslin, Kevin
    Kevin,
    The text component editor is used to construct a label string that is
    formatted according to the modifiers that are selected on the left half of
    that dialog. Edits in that control will effect the next property field
    added to the label. Once you have added the property field, the formatting
    information is built into the text string. For example, in the Point label,
    the Elevation component looks like the following:
    <[Point Elevation(Um|P3|RN|AP|Sn|ORD)]>
    The modifiers after the label attribute define the formatting for this text
    component. In order to change one of the modifiers, select the text
    component, change the appropriate values, and select the button with the
    arrow pointing to the right. This will update the formatting modifiers.
    Dan Philbrick
    Autodesk, Inc.
    news:424EAAE9330A583305225339C5E745D8@in.WebX.maYIadrTaRb...
    editing
    > Kevin Breslin
    > as
    > the
    will
    check
    in
    get
    > > Kevin Breslin
