• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Ash254
    Templates not showing up on sections
    135 Views, 8 Replies
    06-26-2012 12:49 PM
    How do i get templates which I have created, to show on the sections, when the sample lines were not drawn perpendicular to the alignment.
    I am getting the template to show only at those sections which are perpendicular to the alignment.
    Please use plain text.
    Valued Contributor
    ccookusi
    Re: Templates not showing up on sections
    06-26-2012 01:09 PM in reply to: Ash254
    What version of Civil 3D are you using?
    Windows 7 Pro x64
    Civil 3D 2013 (SP1)
    Dell Precision T1650
    i7 3770
    NVIDIA Quadro 2000
    SSD Boot
    12 GB Ram
    Ash254
    06-26-2012 01:14 PM in reply to: ccookusi
    Civil 2011
    Valued Contributor
    ccookusi
    06-26-2012 01:15 PM in reply to: Ash254
    You need to be using 2012 or 2013 to accomplish that..
    Windows 7 Pro x64
    Civil 3D 2013 (SP1)
    i7 3770
    NVIDIA Quadro 2000
    SSD Boot
    12 GB Ram
    Ash254
    06-26-2012 01:16 PM in reply to: ccookusi
    bummer!!!!
    thank you very much
    Ash254
    06-26-2012 01:36 PM in reply to: Ash254
    hey ccookusi
    i would try it tomorrow in 2012, but if you can tell me how to go about doing that i would very much appreciate it.
    Valued Contributor
    ccookusi
    06-27-2012 06:10 AM in reply to: Ash254
    You shouldn't have to do anything.
    Just call it up in 2012 and you should see the interpolated corridor in those sections.
    Windows 7 Pro x64
    Civil 3D 2013 (SP1)
    i7 3770
    NVIDIA Quadro 2000
    SSD Boot
    12 GB Ram
    Ash254
    06-29-2012 02:22 AM in reply to: ccookusi
    i tried doing it in c3d2012 but that did not wk.
    Thnak you for the help though
    Active Member
    John_v1
    06-29-2012 01:10 PM in reply to: Ash254
    1) Create a corridor surface
    2) create the sample lines  ( you should do the sampling for corridor surface) and you can roate them to required angle
    3) create the sections.
