• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Contributor
    wizengr
    TRAFFIC STRIPE LINK FOR ASSEMBLY
    118 Views, 3 Replies
    12-03-2012 04:55 PM
    I have an assembly with which I created my corridor model for visualization. My problem is how to insert a Subassembly link that will represent traffic stripes on the Corridor Model on 3D View. I will appreciate if anyone could walk me step-by-step towards achieving that. Attach is my assembly.
    Please use plain text.
    *Expert Elite*
    Re: TRAFFIC STRIPE LINK FOR ASSEMBLY
    12-04-2012 10:14 AM in reply to: wizengr
    Take a look at the Help for Code Set Styles.
    Some of the lane subassemblies have a setting for Crown Point, which might default to No. Be sure this is set to Yes for one of the lanes that meet at centerline. You can use the crown as your traffic stripe.
    Tim Corey, Owner
    Delta Engineering Systems
    Redding, CA
    Autodesk Authorized Value-Added Reseller
    Active Contributor
    wizengr
    12-04-2012 10:32 AM in reply to: tcorey
    Suppose I want to have a 4-inch Striping in the middle of my Lane, how do I go about it having another link in the middle of the existing lane link?
    Maybe something (like a line or link) has to be offset and raised above the existing Lane Subassembly
    *Expert Elite*
    12-04-2012 10:47 AM in reply to: wizengr
    I think I see what you're trying to do. You just trying to add a stripe for a plan view? Something you can quantify using Quantity Takeoff?
    I would add a LinkWidthandSlope subassy from the Generic tab at centerline, running at the same slope as the lane, but half the lane width. Set Omit Link to Yes for this subassy. Then add another of the same subassy, but with OmitLink off and give it a unique link name. You can run it right over the top of the existing lane subassy.
    Tim Corey, Owner
    Redding, CA
