• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Contributor
    Switching to Civil 3D from Carlson
    251 Views, 5 Replies
    02-08-2013 03:00 PM
    I need to get up to speed on Civil 3D 2012 for design and survey field purposes. I am pretty good at using Carlson, but this Civil 3D is a different beast. I need some type of training for moderate to advanced users. Does anyone have a good book suggestion that comes with demo dwgs? I need help in all of this dynamic stuff, and file structure issues. I have been reading posts and asking questions as I get to an issue, but sometimes I just don't know what questions to ask until I've spent a lot of time on an issue.
    AutoCAD Civil 3D 2012 SP2
    Windows 7 (64)
    Please use plain text.
    Re: Switching to Civil 3D from Carlson
    02-08-2013 03:27 PM in reply to: jamesbarnett
    Mastering AutoCAD Civil 3D is a good one and has downloadable tutorial drawings.
    neilyj
    02-09-2013 01:44 AM in reply to: jamesbarnett
    i agree with Jeff, google and YouTube are also worth trying.
    neilyj
    (No connection with Autodesk other than using the products in the real world)
    IDSP Premium 2014 (mainly Civil 3D 2014 but also 3ds Max Design)
    Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
    16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
    NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
    Joe-Bouza
    02-09-2013 06:53 AM in reply to: jamesbarnett
    "Scraped Knuckles & Tears" By I. D. Ittalone & Q.A. Deeskuschangroop. :smileywink:
    Seriously, Good Luck - You'll be up to speed before you know it.
    I believe 90% is desire.
    Thank you
    Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
    HP Z210 Workstation
    Intel Xeon CPU E31240 @ 3.30 Hz
    12 GB Ram
    Note: Its all Resistentialism, so keep calm and carry on
    64 Bit Win7 OS
    Active Contributor
    cpennetti
    02-09-2013 10:48 AM in reply to: jamesbarnett
    I've actually used both applications, a lot.  I'm using Civil 3D at about 100% right now.  If you were able to get pretty good with Carlson, Civil 3d shouldn't be an issue to pick up, and it's a lot more enjoyable to work with.
    one of the first steps would be to find a good template.  keep in mind that unlike Carlson, the Civil 3D objects cant be modified the same way Carlson CAD parts could be modified.  meaning if you didnt like the way Carlson plotted a profile, you could just manually edit, whereas Civil 3D essentially builds dynamic blocks edited through styles.
    The part catalogs are a similar case... the catalog is about the only external file outside of the .dwg with C3D, and you'll want to set it up so that you have some good parts to build from.
    As a firm, you also want to determine how extensive you want to model your design.  Civil 3D can do a lot, but it doesnt mean it's required... like do you model just storm manholes, or model the inlet up top as well?
    Feel free to ask any specific, i can try and translate Carlson - Civil 3D
    Active Contributor
    02-11-2013 05:42 AM in reply to: jamesbarnett
    Thanks guys. I know there is a lot of different stuff out there, and so much of it is free, but I needed some direction. I read what the Mastering Autocad book was about and I think that will be what I need.
    Windows 7 (64)
