• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Civil 3D
    *Janet Manzano
    Swath width
    110 Views, 1 Replies
    06-02-2004 07:32 PM
    What is swath width or swath?
    Please use plain text.
    *Karl Fuls
    Re: Swath width
    06-03-2004 02:34 AM in reply to: *Janet Manzano
    When you sample for cross sections, the 'swath width' is the distance (left and right) from centerline that will be sampled from the specified surface. These values will determine the overall width of your sampled cross section. Using 25 left and 25 right will give you an existing cross section sample of 50'. It is better to err on being too wide than too narrow when specifying swath widths to make sure you have adequate sampling for tie in of cut fill slopes. I suspect you are using Land Desktop and not Civil 3D, which is a separate software package and the focus of this specific forum. You way want to post future questions to the Land Desktop forum. You may also want to run through some of the tutorials included in LDT (via the Help pulldown) that will walk you through the process of cross section design. Hope this helps, -- Karl Fuls PLS Autocad AEC Training and Consulting Autodesk Discussion Group Facilitator Janet Manzano wrote: > What is swath width or swath? -- Karl Fuls PLS Autocad AEC Training and Consulting Autodesk Discussion Group Facilitator
