• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    IanMcClain
    Accepted Solution
    Survey Points not updating after browse to observation and edit
    290 Views, 12 Replies
    12-05-2012 04:07 PM
    In 2012, the survey cogo points no longer seem to update after browsing to the observation data, making an edit and then saving. It worked fine in 2010. Anyone else running into this?
    -Ian McClain
    (running C3D 2012 sp3, Win7 64bit)
    Please use plain text.
    Product Support
    Re: Survey Points not updating after browse to observation and edit
    12-07-2012 08:37 AM in reply to: IanMcClain
    Could you please be a little more specific with your description of the issue? Are you unlocking the points from a survey database, then editing them from the "edit points"?
    Seth Hall
    Product Support
    GCSO - CSS - FTS
    Autodesk, Inc.
    Being Civil
    Being Civil Twitter
    Being Civil Facebook
    IanMcClain
    12-07-2012 09:47 AM in reply to: IanMcClain
    Here is what I'm doing:
    1.Select a cogo point created from a survey database import event, specifically an .FBK file with total station data.
    2.Right click and select "Browse to Observation Data"
    3.In the panorama vista change a "Target Height" for one or more points.
    4.Save the changes and dismiss the panorama vista.
    Normally this would update the elevation of the point in my drawing, but this is not happening for me in 2012. Changes to a point description update like normal, though.
    -Ian McClain
    Product Support
    12-07-2012 10:12 AM in reply to: SethHall
    Once the points are in the drawing did you try unlocking them before making the edits?
    Seth Hall
    Product Support
    GCSO - CSS - FTS
    Autodesk, Inc.
    Being Civil
    Being Civil Twitter
    IanMcClain
    12-07-2012 10:59 AM in reply to: SethHall
    No, normally I never do that. Once you unlock a point it disconnects it from the Survey Database and edits to the database will not get pushed into the drawing. I just tested it and the point became a simple cogo point and right-cllicking no longer gives the option to browse to survey data. See attached.
    Scale factor is not being pushed to the drawing points either. In the second attached pick I've changed the scale factor for all points and the targed height for point 9146. You can see the survey preview lines in green staking out the calculated positions for the points landing short of the initial points imported with a scale factor of one.
    -Ian McClain
    Product Support
    12-10-2012 08:02 AM in reply to: IanMcClain
    If you made changes to the survey database, then reinserted the points, do the elevation now show the changes you made?
    Seth Hall
    Product Support
    GCSO - CSS - FTS
    Autodesk, Inc.
    Being Civil
    Being Civil Twitter
    IanMcClain
    12-10-2012 09:08 AM in reply to: SethHall
    No, they do not. If I check the points listed in the survey database they don't show any different change in elevation, despite target height edits. It's as if there is a disconnect between the survey observations and the point coordinates in the survey database. The only way I can see to update it is to delete the import event, edit the FBK and make a new import event. I wanted to avoid doing that, since I've already made edits to descriptions, but I'll just have to copy those into the FBK as well.
    -Ian McClain
    Product Support
    12-10-2012 09:20 AM in reply to: SethHall
    Are you saving to the survey database from the observation editor?
    I tested this using the FBK shipped with the tutorial files and change the height to something rediculous like 50.00'. After saving the change back to the database, then resinserting the points, the elevation was updated.
    Seth Hall
    Product Support
    GCSO - CSS - FTS
    Autodesk, Inc.
    Being Civil
    Being Civil Twitter
    IanMcClain
    12-10-2012 09:32 AM in reply to: IanMcClain
    I am saving.  I'll test on a co-workers machine.
    -Ian McClain
    IanMcClain
    12-10-2012 09:45 AM in reply to: IanMcClain
    Tested on a coworkers machine with 2012 and got the same result: point elevation is not updating.
    -Ian McClain
