AutoCAD Civil 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Survey Database 2013
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Recently I upgraded to 2013 and I been having some isssues with my survey DB, first of all I created a base datashortcuts project template folder with all my folders and a default Survey DB.
This is where some of the problem begins, once I create my project, and import points to the default DB, I have no access to the Figure Properties. Is this feature, that worked in 11 & 12 now broken in 13? I have gone in to the setting and copied a new files to the folder several times, to no avail, and there are no other versions of C3D on this machine.
Now for the weird one.
So now that I have my points in the drawing, I go to translate them to my survey, generally I will utilize line in the drawing between field data, and platted data to translate and rotate to the platted lot or lots and the work from there on any calcs or changes. However, when my OSNAP toolbar is docked and locked and I go to select a point line the midpoint, I have no access to the OSNAPS. This also, worked in 11 & 12, but seems broken in 13.
Am I the only one experiencing these issues with 13, if so can anyone think of a solution or cause.
Thanks in advance.
Re: Survey Database 2013
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
bump
