AutoCAD Civil 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Surface memory size
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hello guys,
How can I know the memory size of a TIN or DEM surface? I have a very dense points data to create a surface and I would like to test what option would be the best: simplify the surface removing points or make it raster...
Thanks!
Civil Engineer - www.trentoengenharia.com.br
Autocad Civil 3D 2013 - Infrastructure Design Suite
Windows 7 64 i7 860 @2.80GHz 8GB Ram Quadro 2000D
Re: Surface memory size
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
One option would be to create the surface in a new, clean drawing. Then data shortcut in the surface to your project files. This will keep your drawing file sizes to a minimum and your memory usage down.
*Civil 3DJ*
Todd Rogers
Visit my blog here.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You could also copy the drawing with nothing but the surface in it and test the different methods of reducing the file size.
Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
__________________________________________________________
Credit where credit is due! Give kudos or accept as solution whenever you can.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Also, remember that the drawing size will be impacted by the surface style in use when last saved. For example, your saved drawing will be smaller if the surface style is a "No Display" style versus a style which displays contours and TIN lines.
HTH.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks guys, what you are suggesting can indicate the proportional impact of each surface... and maybe it should be good enough.
But I was expecting to calculate the TIN memory size by the number of triangles and its size in bytes vs the number of pixels and its size in bytes. So I guess I should write a VB code to be able to get the number of triangles (TIN) and valid pixels (DEM).
Isn't this the memory size of these ARX objects?
