• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Distinguished Contributor
    Surface from Corridor loses definition
    182 Views, 4 Replies
    10-31-2012 09:37 AM
    C3d 2011 updated to all service packs
    39 meg overlot design file
    I have had this issue at least 3 times and twice on the same drawing.  I create a surface from corridor and add several polylines and feature line as well as a boundary to the surface.  Randomly it will lose all definition (breaklines and boundary) and i will have to "select similar" (and hope I get everything) and add all of my definition back.
    Any ideas why it does this?  It seems to only occur on large files and when my frequency is tight on curve and vertical curves.
    Please use plain text.
    Re: Surface from Corridor loses definition
    10-31-2012 04:04 PM in reply to: clay_carr
    This may or may not help, but it is generally considered bad practise to edit a corridor surface.  Instead, make a new blank surface, paste in the corridor surface, then add extra data to this new surface.  Make sure you rebuild it whenever the corridor changes.
    Matt Kolberg
    Cansel - Autodesk Division
    http://www.cansel.ca/
    11-01-2012 07:23 AM in reply to: mathewk
    no kidding?...I have never heard that or heard of your workaround for edits.
    I need to ask this communtiy:  Is this a common practice that I have overlooked?
    At our company we have always done the edits (adding breaklines, boundaries and contour) to the corridor surface and only recently has this become a problem.  I will give your advice a shot and see if it helps.  Thank you for the advice.
    11-01-2012 08:54 AM in reply to: clay_carr
    The method Matt mentioned is the one I have used since my second corridor, many moons ago. The corridor surface should remain untouched by the user outside of the Corridor Properties.
    11-06-2012 12:55 PM in reply to: Jeff_M
    I have started using the method mentioned above and I am getting the same results (surface loses breaklines, boundary and contour data added to pasted surface).
    Regardless, I will continue to use the "paste" method in future projects.  Perhaps it is a corrupted file.
