• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    RDW
    Active Member
    Surface creation
    52 Views, 1 Replies
    12-02-2004 08:33 AM
    I’ve noticed that in Civil 3D, creating a surface from contour data requires turning off / removing all data but the contours as there is no option to “select contours by layer” as in LDDT.
    Am I missing something obvious?
    Please use plain text.
    *Dave Simeone
    Re: Surface creation
    12-02-2004 01:22 PM in reply to: RDW
    Howdy - Unfortunately this is a known limitation with R2005. We've got this listed as a requirement for future releases. For now you can isolate the layer OR use the AutoCAD selection set functionality (ie, build a selection set before running the command and then use the selection set when promoted to select plines). Thanks DAS "RDW" wrote in message news:12021516.1102005211102.JavaMail.jive@jiveforum1.autodesk.com... > I've noticed that in Civil 3D, creating a surface from contour data requires turning off / removing all data but the contours as there is no option to "select contours by layer" as in LDDT. > > Am I missing something obvious?
