• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Valued Contributor
    Surface contours do not print
    423 Views, 28 Replies
    07-24-2007 01:56 PM
    I have a surface with 1' and 5' contours. In model space the surface behaves normally - I can select it, add labels, change the properties, etc.
    But...I have several paperspace layouts and in some of them the surface is not 'selectable', it is visible but I cannot select the object (as though it didn't exist). It does not show up in the print preview or the actual plot either. (Oddly enough, the contour labels are selectable and do print out just fine...)
    Any suggestions? The paperspace layouts are pretty much identical (plan and profile sheets of a road). There are no layout overides of any sort as far as linetype, visibility, etc. Help!
    -dale
    Please use plain text.
    *wfb
    Re: Surface contours do not print
    07-24-2007 02:09 PM in reply to: eladkcem
    You may have a style that is associated with the "0" layer. Check for this
    layer to be on & thawed. Make sure you also check in Layer Manager that the
    VP Freeze is not selected. (Viewport Freeze). Check in Model Space when you
    are in Paper Space.
    Bill
    wrote in message news:5668025@discussion.autodesk.com...
    just fine...)
    -dale
    *Matt Kolberg
    07-24-2007 03:54 PM in reply to: eladkcem
    Also, make sure it's not on layer DEFPOINTS.
    Matt
    Valued Contributor
    07-24-2007 04:43 PM in reply to: eladkcem
    Every layer is on. There are NO frozen layers (or VP freezes). I also checked and nothing is on the defpoints layer either.
    any other suggestions? thanks..
    *Matt Kolberg
    07-24-2007 04:47 PM in reply to: eladkcem
    The contours may be set to defpoints right within the style. Check that
    next.
    Matt
    Valued Contributor
    Audit command does not find any errors...
    Valued Contributor
    07-24-2007 04:48 PM in reply to: eladkcem
    also checked the style itself:
    the contours are on x-topo-mnr and x-topo-mjr
    *wfb
    07-24-2007 05:35 PM in reply to: eladkcem
    Well, we have nearly run the gamit, check for no-plot layers.
    Bill
    wrote in message news:5668226@discussion.autodesk.com...
    Valued Contributor
    07-25-2007 04:02 PM in reply to: eladkcem
    Unfortunately, there aren't any no-plot layers either. Every single layer is on, unfroze, and set to print (and there are no vp overrides).
    Is there any way of exporting the paperspace layouts and the objects of the file to another file to see if I can get rid of the problem that way?
    thanks
    -d
    Distinguished Contributor
    07-25-2007 05:11 PM in reply to: eladkcem
    You say this only happens in some viewports. What happens when you copy the layout(s) in question (right-click on the layout tab)? Do the copies display correctly?
    Another way-out-there-and-off-the-show idea I had was that maybe the surface in question is being masked by another that is being rendered or something (e.g. the EG is behind the FG, which latter has faces displayed with a 3D Hidden visual style)... but without seeing the drawing, I'm only guessing. When you try to select the surface in question, is it selecting something else instead?
    With reference to copying layouts to another file, I've always used Copy and Paste to Original Coordinates without hassle, but IIRC there are (were) some caveats to that process.
    Trevor
