• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Distinguished Contributor
    Surface Table Names
    257 Views, 6 Replies
    07-06-2011 04:29 AM
    Is there a way for a table linked to a surface (ie. a volume table) to display the surface name in the header? There seem to be no options to do so and copy/pasting <[surface name]> into the header text box just returns a number, oddly.
    I will have upwards of 40 surfaces and I don't want to have to manually edit each one!
    Seems like a bizarre and simple omission seeing as the tables are dynamically linked to the surface anyway.
    Any ideas?
    Cheers,
    Kevin
    Please use plain text.
    Re: Surface Table Names
    07-06-2011 09:02 AM in reply to: ksorsby
    I ran into that issue once.  Unfortunately, I found no good way to do it.
    For me, it wasn't too bad, because I only had a couple of Surfaces, so I created a Table Style for each one.  I wouldn't want to do that for 40 Surfaces, though...
    Sinc
    07-06-2011 10:03 AM in reply to: Sinc
    I thought as much. I'm going to file this one under Half-Baked Functions That Autodesk Can't Be Bothered To Sort Out.
    Cheers,
    Kevin
    07-06-2011 10:27 AM in reply to: ksorsby
    Yeah, there's an awful lot of C3D that falls into the "half-baked" category....
    It gets frustrating.  But on the flip side, it's possible to do an incredible amount of high-quality work in a very short time frame with this software, even in its current "half-baked" state.  So if it ever gets "fully baked", it should be pretty awesome...  :smileywink:
    Sinc
    Active Contributor
    12-19-2012 09:16 PM in reply to: Sinc
    Plus one... Please ADD!!
    Civil 3D 2013 (SP1)
    Win 7 Pro x64
    DELL Precision Workstation T3500
    Intel Xeon 3.3GHz (w3680)
    24Gb Ram
    NVIDIA Quadro 2000 (1GB)
    Active Contributor
    01-03-2013 03:58 AM in reply to: bkanthergolder
    can you insert a field into the table style? use object. then name... just guessing at this point
    Windows 7 64
    Intel Core i7 2.0 GHz 2.0 GHz
    8 GB RAM
    Nvidia GeForce GTX460M
    Civil 3D 2012 SP2.1
    01-04-2013 02:23 AM in reply to: d1of2
    There's no option or dropdown that I can see to enter anything other than text into the header text component editor.
    It's a royal PITA when you've got a lot of tables lying around.
    Kevin
