• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    *Expert Elite*
    Re: Surface Manipulation
    02-15-2013 12:02 PM in reply to: fcernst
    You say my suggestion in unworkable.  In the absence of your wish coming true, what are you doing?  Do you prefer the Chappel solution? To my mind they take about the same to set up and are both dynamic.  My solution has the advantage of giving a nice report broken down by areas.
    Your wish involves the volumes dashboard.  Since I'm still working in 2011 I haven't had a chance to see that yet, so I can't really understand or comment on the wish.  I'll check it out when I get a chance.
    As for pasting and managing surfaces: pasting is quick, and managing is non-existant.  Drawing boundaries does take time.  What does managing surfaces mean?
    Since I'm the only one in the office who does earthworks I presume hours budgeted on new projects is based on how long I took on the previous one.  I do my best to set things up sensibly so that if I don't work on a project for a while and then have to go back two years later I'll understand what was done and where I left off; or so that I can hand over to a coworker if one was asked to get into it.  I'm willing to look at new ideas, and I support your wish if it's going to save me time.  But I am interested in your current workflow, since you obviously feel it is better than mine.
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
    Please use plain text.
    Valued Mentor
    fcernst
    02-15-2013 12:21 PM in reply to: troma
    No, I don't have any current better solution than you or the Chappel solution. That's the whole point.
    The software has no current elegant solution for correct subgrade earthwork analysis.
    The Volumes Dashboard is a nice interface. Just a couple tweaks to that, place it on a Tab under Surface Properties, and Autodesk would have the elegant, one surface solution I propose.
    Ernst Engineering
    Fred Ernst, PE
    C3D 2013 SP1, C3D 2014
    W7x64; i7 8gb; Radeon HD 5700
    www.ernstengineering.com
    Active Contributor
    02-15-2013 05:25 PM in reply to: blotridge
    100% agreed. This is something that Autodesk must do to stay relevant with communities othe than civil engineers.
