AutoCAD Civil 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Surface Boundary only showing portion of surface within the boundary
- Highlight
- Email to a Friend
- Report Inappropriate Content
I used a 2d polyline to create a surface boundary for a surface created. The polyline is a closed loop. For the boundary type it is outer, unchecked Non-destructive breakline, and mid-ordinate distance = 1.
My problem is that when I do this I only get a small portion of the surface to show up within my surface boundary. If I don't have a surface boundary the entire drawing surface shows up no problem.
The purple polyline is my boundary and the light blue is the surface created within the boundary.
Any help would be greatly appreciated. Thanks
Re: Surface Boundary only showing portion of surface within the boundary
- Highlight
- Email to a Friend
I see this sometimes. Have you made sure that your outer boundary is last on the surface definition list? If so, I might also try a 'mapclean' of your boundary polyline, try leaving 'Non-destructive breakline' checked when you create your outer surface boundary, and make sure all the points you want to include in your surface are definitely included in the point group you're using.
HTH.
- Highlight
- Email to a Friend
More detail would help us find a solution to this issue.
What are the green lines that we see? Looks like TIN lines, but the islands don't connect.
What data were used to create the surface? Point groups? Contours? Breaklines? Can you make us an image with the surface data showing, along with the proposed boundary, but no other graphics?
Or
Post your drawing.
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
- Highlight
- Email to a Friend
Here's my two cents: Does your 2D polyline have any duplicated vertices?
