• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Member
    Subtract one surface from another.
    1061 Views, 6 Replies
    11-24-2009 11:10 AM
    Hello all,
    I am in need of subtracting Surface A from Surface B to display the surface intersections between the two. I have a geological top of clay surface and a bottom of clay surface where the bottom intersects with the top thus showing holes in a geological clay layer. I am wanting to know if Civil 3D supports the subtracting of two surfaces.
    Thank you!
    Please use plain text.
    *Terry W. Dotson
    Re: Subtract one surface from another.
    11-24-2009 12:21 PM in reply to: CAD_Avatar
    Don't claim to be an expert, but you should be able to create a 'Volume
    Surface', using care in specifying the order of base/compare surfaces.
    Then contour elevation 0.0.
    Terry
    Never start any job without the right tools!
    AutoCAD Add-on Tools at http://www.dotsoft.com
    *Expert Elite*
    BrianHailey
    11-24-2009 12:30 PM in reply to: CAD_Avatar
    Terry, if you are just trying to get the intersection of the two surfaces, the order they are added (base vs. comparison) doesn't matter.
    Brian Hailey
    http://www.cad-1.com
    http://www.AtYourDeskTraining.com
    *Terry W. Dotson
    11-24-2009 04:01 PM in reply to: CAD_Avatar
    > matter.
    True, but todays 'just' is often tomorrows 'first of many', so might as
    well build it right today.
    Terry
    New Member
    11-21-2012 05:49 AM in reply to: *Terry W. Dotson
    Terry
    When i do what you say, the result volume surface is in the wrong elevation.
    Example: my surface "1" is in (+-) elevation 235.600 and my surface "2" starts from 235.850 to 235.450 (it's like a cup), when i do the volume surface, the result goes to elevation 0.0 (+-), and when i do contour elevation 0.0, it gives me the interserction but in the wrong elevation! how do i put this in the right elevation? because what i want is the (surface 1)-(surface 2)
    thanks for your time
    Ivo Costa
    *Expert Elite*
    11-21-2012 07:59 AM in reply to: CAD_Avatar
    The elevation you're seeing is the difference in elevation between the two surface; surf 1 minus surf 2. This is what it seems like you asked for. So you have your contour line representing where they intersect and all you need now is its elevation to match the surfaces?
    Turn it into a feature line and use the surface from elevation tool.
    Matt Kolberg
    Cansel - Autodesk Division
    http://www.cansel.ca/
    *Expert Elite*
    BrianHailey
    11-21-2012 08:46 AM in reply to: mathewk
    If you don't have a good understanding of how Sites work within Civil 3D, I would recommend that you don't use a featureline, just use the same tool and assign the elevations to the polyline instead. If you want more inforomation on why I recommend this, check out THIS.
