AutoCAD Civil 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Subtract one surface from another.
- Highlight
- Email to a Friend
I am in need of subtracting Surface A from Surface B to display the surface intersections between the two. I have a geological top of clay surface and a bottom of clay surface where the bottom intersects with the top thus showing holes in a geological clay layer. I am wanting to know if Civil 3D supports the subtracting of two surfaces.
Thank you!
Re: Subtract one surface from another.
- Highlight
- Email to a Friend
Don't claim to be an expert, but you should be able to create a 'Volume
Surface', using care in specifying the order of base/compare surfaces.
Then contour elevation 0.0.
Terry
Never start any job without the right tools!
AutoCAD Add-on Tools at http://www.dotsoft.com
- Highlight
- Email to a Friend
Brian Hailey
http://www.cad-1.com
http://www.AtYourDeskTraining.com
- Highlight
- Email to a Friend
> Terry, if you are just trying to get the intersection of the two
> surfaces, the order they are added (base vs. comparison) doesn't
> matter.
True, but todays 'just' is often tomorrows 'first of many', so might as
well build it right today.
Terry
- Highlight
- Email to a Friend
Terry
When i do what you say, the result volume surface is in the wrong elevation.
Example: my surface "1" is in (+-) elevation 235.600 and my surface "2" starts from 235.850 to 235.450 (it's like a cup), when i do the volume surface, the result goes to elevation 0.0 (+-), and when i do contour elevation 0.0, it gives me the interserction but in the wrong elevation! how do i put this in the right elevation? because what i want is the (surface 1)-(surface 2)
thanks for your time
Ivo Costa
- Highlight
- Email to a Friend
Turn it into a feature line and use the surface from elevation tool.
Cansel - Autodesk Division
http://www.cansel.ca/
- Highlight
- Email to a Friend
If you don't have a good understanding of how Sites work within Civil 3D, I would recommend that you don't use a featureline, just use the same tool and assign the elevations to the polyline instead. If you want more inforomation on why I recommend this, check out THIS.
