• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    *Expert Elite*
    neilyj
    Subscription Content to Ribbon
    258 Views, 10 Replies
    11-09-2012 01:23 AM
    All my Subsription Content is currently accessed via the Toolbox in Toolspace.
    Can this content be put on a Ribbon panel (under the Plug Ins tab for example as in screenshot) for ease of access?
    neilyj
    (No connection with Autodesk other than using the products in the real world)
    IDSP Premium 2014 (mainly Civil 3D 2014 but also 3ds Max Design)
    Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
    16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
    NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
    Please use plain text.
    *Expert Elite*
    Re: Subscription Content to Ribbon
    11-09-2012 03:49 PM in reply to: neilyj
    Absolutely.
    Just open CUI and make new commands whose macros call the same commands that are called when you execute from the Toolbox tab. Once the new commands are made, they can be drag onto panels (existing or new.)
    Tim Corey, Owner
    Delta Engineering Systems
    Redding, CA
    Autodesk Authorized Value-Added Reseller
    *Expert Elite*
    neilyj
    11-10-2012 01:34 AM in reply to: neilyj
    thanks Tim, i thought it would be possible. I'll try it on Monday and post back if i run into problems
    neilyj
    *Expert Elite*
    neilyj
    11-11-2012 12:07 PM in reply to: neilyj
    Attached some toolbox screenshots of the items I want to put on the ribbon, I'm not entirely sure what command/macro goes where and would be grateful for some guidance.
    neilyj
    Valued Mentor
    11-12-2012 02:12 AM in reply to: neilyj
    Neil, as these are external commands you will need to add new commands into the CUI for this.
    As Civil3d is aware of the commands this makes life a bit easier so add the command to the interface Rbd & Genioimport etc, however I'm not sure how you will get it into the Tab as I haven't had to do this yet Iv'e only done this by creating a Toolbar and converting it to a ribbon.
    Mike
    *Expert Elite*
    11-12-2012 11:11 AM in reply to: neilyj
    Here's a video on how to do that, Neil. As an added bonus, I also show you how to fix your mistake when you type the command name wrong the first time.:smileywink:
    http://www.youtube.com/watch?v=NNOA83G64nU
    Best regards,
    Tim
    Tim Corey, Owner
    Redding, CA
    *Expert Elite*
    neilyj
    11-12-2012 01:57 PM in reply to: tcorey
    Tim, many thanks for taking the time to do the video - it's much essier to follow the CUI steps via this method.
    I've a few other routines that I'll also put on the Riboon now....
    neilyj
    *Expert Elite*
    neilyj
    11-13-2012 04:27 AM in reply to: neilyj
    Typing RBD only seems to work after running the importer from the toolbox first - does something else need to be loaded on startup??
    neilyj
    *Expert Elite*
    11-13-2012 08:27 AM in reply to: neilyj
    Sorry, I didn't even check that. Use this code for the macro:
    ^C^C(command "netload" "C://ProgramData//Autodesk//C3D 2013//enu//Data//Reports//Net//boreholes.dll");rbd;
    That will work if you are using the default Data directory for Civil 3D. If not, you'll need to replace the folder structure in this command.
    Tim Corey, Owner
    Redding, CA
    *Expert Elite*
    neilyj
    11-13-2012 08:43 AM in reply to: tcorey
    No problem - thanks for the revised code line
    neilyj
