• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Member
    trunk_boy
    Subassemby properties error
    163 Views, 1 Replies
    08-17-2011 10:28 AM
    Hi all, so I am not really sure what i broke but for some reason when i go into subassemby properties for the LaneSuperelevationAOR subassembly, what used to be drop downs with options is not numbers. i.e. Side: left=1, right=2 etc, etc.This came about when i edited the properties by right clicking the subassembly in the tool palette. The LaneSuperelevationAOR seems to be the only one affected.
    I tried repairing the installation, no luck. I also tried over writing the stocksubassemblies.dll file under C:\ProgramData\Autodesk\C3D 2012\enu, no luck. I can still use the subassemblies, but any help is appreciated because its annoying.
    Oh and also the subassemblies that were in the drawing already (LaneSuperelevationAOR) are not affected.
    im attaching a couple shots of what it looks like. thanks
    Please use plain text.
    Active Member
    trunk_boy
    Re: Subassemby properties error
    08-17-2011 12:44 PM in reply to: trunk_boy
    **what used to be drop downs with options is NOW numbers
