• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Contributor
    Subassembly - Tunnel
    1632 Views, 6 Replies
    05-14-2008 08:55 AM
    Dear guys,
    anybody create a custom subassembly (tunnel), I need something ideas.
    regads, daniel
    Please use plain text.
    Active Contributor
    Re: Subassembly - Tunnel
    05-14-2008 09:01 AM in reply to: daog
    file in dwg format. I need your help.
    thanks again. daniel
    *wfb
    05-14-2008 10:34 AM in reply to: daog
    Daniel:
    You are faced with problems. As far as I know you cannot have an assembly
    with points above and below, which you apparently do.
    Bill
    wrote in message news:5930990@discussion.autodesk.com...
    *Expert Elite*
    05-14-2008 10:37 AM in reply to: daog
    http://civilcommunity.autodesk.com/blogs/blog/6/blogpost/3758/
    Your going to have to search for the other 2 posts from Ove.
    Christopher
    http://civil-3d.blogspot.com/
    Civil Reminders
    http://blog.civil3dreminders.com/
    http://www.CivilReminders.com/
    Active Contributor
    05-14-2008 12:11 PM in reply to: daog
    Christopher,
    I have print this topic, but I have something problem with this custom assembly. Can you give addicional idea.
    regards, daniel.
    *Expert Elite*
    05-14-2008 01:47 PM in reply to: daog
    What exactly is the problem?
    The only issue I'm aware of is that surfaces cannot have vertical faces, and a single surface cannot overlap itself. So the assembly would need to generate multiple surfaces. But that's not a problem, it just takes care.
    -- Sinc
    http://www.ejsurveying.com
    http://www.quux.biz (Sincpac-C3D)
    Sinc
    Active Member
    wedzisi
    09-30-2011 07:05 AM in reply to: daog
    hi i am interested how you create thes subassembly i am tring learn civil 3d my self in my country isnot eny training center or somone woo will teach me . plzz if you can explane  it will be great.  thx
