• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Subassembly - Generic pavement not showing its parameters
    130 Views, 3 Replies
    01-15-2013 03:41 AM
    Hi all,
    Just a quick query hopefully it is only requires a simple solution.
    When i am creating a assembly, the sub assembly parameters for the generic pavement structure is not showing (such as the lane width or crossfall) Other sub-assemlies show these parameters. Is this a bug or is there a way i can turn this on.
    I can change the parameters on the properites.
    Thanks for your help.
    Please use plain text.
    Adriano_cad
    Re: Subassembly - Generic pavement not showing its parameters
    01-15-2013 04:15 AM in reply to: karen.woodward
    Hello
    That seems a bug, try another file and look to update for AutoCAD Civil 3D.
    Adriano Oliveira
    MaxiCAD Informática
    www.maxicad.com.br
    01-15-2013 04:28 AM in reply to: Adriano_cad
    The Autocad Civil 3d is upto date. Seems like the codes are missing as well so the corridor does not show up. it is running fine with other subassemblies.
    Anyone else having the same problem?
    Valued Mentor
    fcernst
    01-15-2013 06:01 AM in reply to: karen.woodward
    Yes, works for me. You have the ability to add your own codes with this SA.
    Ernst Engineering
    Fred Ernst, PE
    C3D 2013 SP1, C3D 2014
    W7x64; i7 8gb; Radeon HD 5700
    www.ernstengineering.com
