• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Valued Mentor
    LeafRiders
    Accepted Solution
    Subassembly Composer - Update existing Custom SAs
    97 Views, 1 Replies
    11-27-2012 06:20 PM
    What's the easiest way to update an existing custom SA once it's in the drawing.
    For example i have some coding that I'd like to change and this particular SA is in use 10 times in my file in different ways. I used the Subassembly Composer to create the original custom SA.
    It's not as easy as saving the file over top of the existing .pkt file, if it was I wouldn't be here. It seems to be behaving like a block would. I need to redefine the Subassembly in order for it to update in the drawing. How is best to do this and is there any tricks to the process. When do i need to open and close Civil in order to apply the new changes.
    Do I need to update the SA in my tool palette as well?  Any and all information that will save me smashing my computer would be great. Thanks. :smileywink:
    Please use plain text.
    *Expert Elite*
    Re: Subassembly Composer - Update existing Custom SAs
    11-27-2012 10:24 PM in reply to: LeafRiders
    http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Update-Subassembly/td-p/3431467
    Matt Kolberg
    Cansel - Autodesk Division
    http://www.cansel.ca/
